I have a faulty beolab penta 3, type 6631where the problem lies with the amp module.
Now I have a beolab penta 2 type 6622, which is still working good.
1) can i use the amp of the penta 2 to fit the penta 3 for one side since only side side is faulty.
2) is the matrix green display able to show as normal?
3) will there be any difference to the sound i.e.: imbalance sound?
Please help. Thanks
I think the straight answer to this is yes! The differences are minimal.
Peter
Hi Peter,
Thanks for the answer.
What exactly is the minimal differences that you are referring to?
It helps my understanding if you are able to elaborate more. Thanks
Cheers
