Can i use a Penta 2 amp on a Penta 3?
flex73
Posts 9
flex73 Posted: Sat, Jun 16 2012 2:39 AM
I have a faulty beolab penta 3, type 6631where the problem lies with the amp module.
Now I have a beolab penta 2 type 6622, which is still working good.
1) can i use the amp of the penta 2 to fit the penta 3 for one side since only side side is faulty.
2) is the matrix green display able to show as normal?
3) will there be any difference to the sound i.e.: imbalance sound?
Please help. Thanks
Peter
Earsdon
Posts 11,991
Peter replied on Sat, Jun 16 2012 9:17 AM
I think the straight answer to this is yes! The differences are minimal.
Peter
flex73
Posts 9
flex73 replied on Sat, Jun 16 2012 9:48 AM
Hi Peter,
Thanks for the answer.
What exactly is the minimal differences that you are referring to?
It helps my understanding if you are able to elaborate more. Thanks
Cheers
Page 1 of 1 (3 items) | RSS
