Picture settings and quality on Beovision Avant 55"
This post has 12 Replies | 1 Follower
Michael
Denmark
Posts 67
Michael Posted: Thu, Jul 30 2015 8:56 AM
Hi guys,
Overall I'm very satisfied with my 6 months old Avant, but I have some issues regarding the picture handling of the Avant, that maybe other owners can confirm or disconfirm.
  1. If I change and store new picture settings on any source, they are all been reset after switching Avant on/off. Why are the settings not stored?
  2. Maybe it's me, but since the last firmware update back in june, I've noticed "ghost effect" around white subtitles with movement in the back (not the ones with black background) and people and other objects in bright light.
  3. This issue is to be seen on any source (cable tv, Netflix, iTunes etc.)
  4. Talked to my B&O dealer, who checked the information on the last firmware update and there isn't anything about changes made to the picture control.
Not sure if I have the right technical explanation, and it makes sense.
I know it sounds crazy and I'm pretty sure this issue hasen't been there all the time, but now I see it all the time, when you know what to look for.
So, if you have an Avant 55" like me, have you noticed the same or not?
Look forward to hear some reaction from you guys Smile
Michael
Denmark
Posts 67
Michael replied on Mon, Aug 3 2015 7:52 PM
Wow, not a single respond - for real or don't you dare..?
Paul W
London
Posts 1,810
Paul W replied on Mon, Aug 3 2015 10:17 PM
Michael from Sweden is the guy to speak to as he's had a lot of issues with his and also he has an incredible eye for detail!
Michael
Denmark
Posts 67
Michael replied on Tue, Aug 4 2015 10:17 AM
Hi Paul, okay thanx a lot. How do I find him?
Millemissen
Flensborg, Denmark
Posts 14,680
Paul W
London
Posts 1,810
Paul W replied on Tue, Aug 4 2015 12:11 PM
Thank you MM :) Hope that you get everything sorted BeoFantast :)
Aussie Michael
Melbourne, AU
Posts 3,730
BeoFantast:
Hi guys,
  1. Maybe it's me, but since the last firmware update back in june, I've noticed "ghost effect" around white subtitles with movement in the back (not the ones with black background) and people and other objects in bright light.
  2. This issue is to be seen on any source (cable tv, Netflix, iTunes etc.)
  3. Talked to my B&O dealer, who checked the information on the last firmware update and there isn't anything about changes made to the picture control.
Oh heyyyy :-) I think i have had mine also 6 months and have had software update in that time.  I haven't found any ghosting.  The only issue i have had with the settings is although it says "adaptive" it doesn't really save.  But saving is per source.  I find i have "adaptive drama" - when i want it to just do the adaptive and change it all the time, and not have me do it .  I get confused, and so i think i have to check the source because when i do save it, i think i'm not saving it properly.
Michael
Denmark
Posts 67
Michael replied on Wed, Aug 12 2015 12:20 PM
Update to picture settings.
Try and change the value for viewing distance to Avant under picture (factory setting is 3,5 M on mine) the picture quality changes radical, when playing with this setting...
Have a go on your own Avant.
ari
Posts 144
ari replied on Wed, Aug 12 2015 12:58 PM
Will play around with mine to see if I notice any difference. Did it improve the "ghosting" you were describing?
Michael
Denmark
Posts 67
Michael replied on Wed, Aug 12 2015 4:44 PM
Not quite sure yet, have to look closer on the "new" setting. I'm also in contact with B&O and looked on two other Avant 55" in store with the same issues as mine.
Stay tuned...
Michael
Denmark
Posts 67
Michael replied on Tue, Sep 15 2015 6:48 AM
New Avant software update 14. september, but what does it do..?
A change back to better motion handling like before, perhaps...
Anyone with more info.
Roger
Norway
Posts 417
Roger replied on Tue, Sep 15 2015 11:00 AM
Regarding the new sw:
They have solved reported issues related to no sound at start-up, dropout in the wireless speaker connection and the issue where multiroom products were unable to discover each other (=no sound distribution). Not sure why the distribution is limited to the Nordic countries (compared to Scandinavia or Europe only) for this week - might be because they want to test it here first...Big Smile Global launch is set to Sept 21st.
Roger
Hiort
Sweden
Posts 2,895
Hiort replied on Wed, Sep 16 2015 3:47 PM
Roger:
Roger
My BV 11 was updated as well.
Page 1 of 1 (13 items) | RSS
