Cable to connect Beocenter 2000 and Macbook Air
Ank
Posts 3
Ank Posted: Fri, Jul 31 2015 9:07 PM
Hi!
I have a question: I bought a Beocenter 2000, the tape deck makes a click sound when I press play. I read that the computer can be connected by the tape copy input. I want to listen to music from my Mac by using the Beocenter and the speakers. What kind of cable suits this plan? I looked on the internet and found this:http://www.cablesonline.com/6ft3matodin52.html Does this suit, the jackplug in the headphone or should I search for an USB output from the Macbook?
Any helpful answer is welcome, thanks!
Anke
Millemissen
Flensborg, Denmark
Posts 14,680
Hi Anke and welcome to Beoworld,
the sound coming from a computer always has to be converter from a digital signal to what we can hear and the amp/theBC2000 can handle. This is a socalled analog signal.
The device, that is needed for this conversion  is a DAC. It is built-in to any computer and the output you usually use is the headphone-output.
For a 'better' conversion, you can use a small external USB-connected DAC.
In either case you will need the required cables. Please have a look at the homepage of Steve at SoundsHeavenly (see link below), or drop him a message/mail with a description of what you want to do.
Some times he reads these posts too - so stay tuned.
Ank
Posts 3
Ank replied on Fri, Jul 31 2015 9:58 PM
Thank you MM!
And what a nice website from Steve
Page 1 of 1 (3 items) | RSS
