Beocom 5 and VOIP
Frederic
Belgium
Posts 121
Frederic Posted: Sat, Jun 16 2012 9:49 PM
Hey everybody,
I have a bc5 with beoline2 and apparently it's possible to use as an IP phone. The manual doesn't state anything to activatenthis feature.
Can anyone  point me in the right direction how do I set this up, do I need some kind of subscription (I live in Belgium).
Many thanks,
Flx
PhilLondon
London
Posts 3,637
This IP thing is just a marketing "lie".
The Beocom 5 can handle 2 lines, which is great, but that's it. It does not handle IP connectivity itself.
However, if your internet router can handle VoIP and has a telephone socket on it, you can then connect this to the line 2 of your phone.
Beoworld app with direct photo upload and emoticons.
valve1
The south of France and occasionally Dublin Ireland
Posts 1,502
valve1 replied on Sun, Jun 17 2012 6:02 AM
Software issues aside, the bc5 would have been some phone if it had been able to handle pstn and voip at the same time.
Heribert
Vorarlberg / Austria
Posts 804
Heribert replied on Sun, Jun 17 2012 7:35 AM
I do have the BC5 and one of the lines from BEoline2 goes into this "router":
http://www.amazon.de/gp/product/B000FWGTAI/ref=oh_details_o00_s00_i00
Works very well. I also do not have any problems with my BC5.
BV 11-46  / Beoplay V1 -40 / Apple TV 1+3 / Beosound Essence MK2 / BL3 / 2* BL11 / BL 6000 / BL 12-1 / BL 2000 / 3 * Beo4 /BL Converter 1611
Frederic
Belgium
Posts 121
Frederic replied on Sun, Jun 17 2012 7:01 PM
Thanks for the tip Heribert, I will try it.  So one Line1 is the classic analog line and the other is the Voip line?
And how this works in real life, you press first L2 to select the Voip-line and the you dial the a number out the memory list.
Does that mean you need to store a number twice (stupid question?) or cannyou pre- program it so a number is by default a voip number?
Heribert
Posts 804
Heribert replied on Sun, Jun 17 2012 7:18 PM
Exactly, one line is standard analogue and the other goes to the Cisco Router. You press L1 for the analogue (in my case) and L2 for the VoIP line. it remembers the latest selection.
Numbers are stored once. You can store up to 3 different numbers per contact (like in your mobile).
kuyttendaele
Posts 707
The BC5 is as much a VoIP phone as the BC6000 or any other classic analogue phone... In other words.. it has nothing to do with IP and B&O's marketing spinned a huge fuzz around it.
You'll need an ATA (analogue telephone adapter) OR a router with voip capabilities / analogue line connection. Without that it's impossible to give the BC5 IP capabilities.
Michael
Sweden
Posts 2,578
Michael replied on Mon, Jun 18 2012 9:03 AM
I use my BC6000's with a voipbox and it works just as good. And I like BC6000 much much more anyway :)
Michael
Sweden
Posts 2,578
Page 1 of 1 (9 items) | RSS
DigiCert Secured Site Seal
