I asked Henrik, the developer of the MLGW/BLGW to explain the mysterious Scheduler feature of the MLGW. This is his explanation:
"The Scheduler is basically a Timer that you can create in the MLGW, this timer you can start, stop and use as a delayed trigger
So in your case you can specify a Scheduler called “VolDownRep” and specify it for 1 sec (just for testing)
Next you can choose if this timer shall only run once and then stop or if it should continue to run when time have elapsed (meaning it’ll run again automaticly)
So in your case we’ll not make it “Run Once” only, this way it’ll continue to run when it’s activated
Next you’ll start this scheduler called “VolDownRep” using a macro that’s triggered from the Lutron Vol- keypad button press (or if your Lutron keypad have the latest FW you could use Hold)
Now you create a new Macro called “VolDownRepeat” this macro is triggered by your Scheduler “VolDownRep” and this macro will send a Vol- command to the B&O system also
Lastly you create a new Macro Called “VolDownRepeatRelease” this macro is triggered by the Lutron Keypad “Release” command and will in turn “Stop scheduler VolDownRep” "
I agree. I only posted the quote from Henrik as his explanation as an example of how to use the Scheduler function. Still, I have combined multiple protocols on a keypad with great results. I have done some nice macros connected to RadioRa 2 buttons that can control RadioRa 2 lighting, Philips Hue lighting, and B&O A/V controls all at the same time. This is where the MLGW truly shines!
beojeff:I agree. I only posted the quote from Henrik as his explanation as an example of how to use the Scheduler function. Still, I have combined multiple protocols on a keypad with great results. I have done some nice macros connected to RadioRa 2 buttons that can control RadioRa 2 lighting, Philips Hue lighting, and B&O A/V controls all at the same time. This is where the MLGW truly shines!
mjmedlo: beojeff: I agree. I only posted the quote from Henrik as his explanation as an example of how to use the Scheduler function. Still, I have combined multiple protocols on a keypad with great results. I have done some nice macros connected to RadioRa 2 buttons that can control RadioRa 2 lighting, Philips Hue lighting, and B&O A/V controls all at the same time. This is where the MLGW truly shines! Very cool. Please tell me more about how you got the BLGW to control Hunter Douglas. Are the Hunter Douglas shades priced better than the Lutron shades? I'm using the BLGW now and have created.. For a friend macro to control Lutron B&O and hunter Douglas They are really nice devices
Very cool.
mjmedlo: beojeff: I agree. I only posted the quote from Henrik as his explanation as an example of how to use the Scheduler function. Still, I have combined multiple protocols on a keypad with great results. I have done some nice macros connected to RadioRa 2 buttons that can control RadioRa 2 lighting, Philips Hue lighting, and B&O A/V controls all at the same time. This is where the MLGW truly shines! Very cool. I'm using the BLGW now and have created.. For a friend macro to control Lutron B&O and hunter Douglas They are really nice devices
Please disregard my last post. I accidentally typed inside of the quote. I can't get the edit or delete functions to work on the forum from Safari.
Please tell me more about how you control Hunter Douglas with the BLGW. Are Hunter Douglas shades priced better than Lutron shades?
beojeff:Please disregard my last post. I accidentally typed inside of the quote. I can't get the edit or delete functions to work on the forum from Safari. Please tell me more about how you control Hunter Douglas with the BLGW. Are Hunter Douglas shades priced better than Lutron shades?
beojeff: I asked Henrik, the developer of the MLGW/BLGW to explain the mysterious Scheduler feature of the MLGW. This is his explanation: "The Scheduler is basically a Timer that you can create in the MLGW, this timer you can start, stop and use as a delayed trigger So in your case you can specify a Scheduler called “VolDownRep” and specify it for 1 sec (just for testing) Next you can choose if this timer shall only run once and then stop or if it should continue to run when time have elapsed (meaning it’ll run again automaticly) So in your case we’ll not make it “Run Once” only, this way it’ll continue to run when it’s activated Next you’ll start this scheduler called “VolDownRep” using a macro that’s triggered from the Lutron Vol- keypad button press (or if your Lutron keypad have the latest FW you could use Hold) Now you create a new Macro called “VolDownRepeat” this macro is triggered by your Scheduler “VolDownRep” and this macro will send a Vol- command to the B&O system also Lastly you create a new Macro Called “VolDownRepeatRelease” this macro is triggered by the Lutron Keypad “Release” command and will in turn “Stop scheduler VolDownRep” "
Thanks, Jeff, for posting this. I`ve tried to program a schedular for some time now without any success - and I posted a question concerning the MLGW schedular here in the forum and in Struer (without any success/reply..), just to find out that it is quite simple. It`s like programming variables with Lintronic...:)
Thanks again
Stefan
mjmedlo:This is a dangerous solution. I don't like the release to trigger. I suggest using the discrete volume up where each button press up gives on one volume level up. Now.. This can be complicated unless you use a 6 button keypad as a 'source'. The arrows normally control the last pressed lighting zone for dimming. I've only used the up arrows as a discrete one level up and down which requires multiple presses but is safer. Also, I've only used on a keypad that did not control any lights but was exclusively used for B&O Good luck!
Good luck!
"release" trigger is a useful command to stop a continious function like dim/brighten light/scenes. That`s how I use it, and it works great.
