jukebox can't make a connection to the sountheart.
This post has 4 Replies | 0 Followers
koning
holland
Posts 4,220
koning Posted: Thu, Aug 13 2015 7:14 PM
The jukebox doesn't see the soundheart.the led on the back is white but it can not make a connection.
What have I done wrong?
Opman
Wilmslow, Cheshire
Posts 443
Opman replied on Thu, Aug 13 2015 9:12 PM
Is this a first time set up or have you had it working previously?
I suggest powering everything off, including router and start again.
Opman
koning
holland
Posts 4,220
koning replied on Thu, Aug 13 2015 9:25 PM
First time.
I think it's the internet connection.
Chris
Ostend-BE
Posts 1,170
Chris replied on Fri, Aug 14 2015 6:23 AM
Congrats, so you finally took the step towards a Moment.
Make sure your wireless is within reach of the Jukebox, it needs a good and strong signal.
"Believe nothing you read and only half of what you see, let your ears tell you the truth."
Beroli
Germany
Posts 316
Beroli replied on Fri, Aug 14 2015 2:38 PM
koning:
Hi Koning,
I did the easy first-start-setup by myself and crashed a wall only after 1 minute. Choose language - check, Country - check, keyboard -check, WLAN - check. "Sorry can not find the soundheart" - crash. After talking with my dealer, getting a replacement and crashing again at the same point - my dealer got a great idea. Maybe there is something wrong with your network. The solution was to change the 6 year old Name of my Network (e.g. "Lost & Found" to LostFound). The Soundheart can not link to the Jukebox, if your WLAN-Network-SSID includes any special charakters or spaces.
Hope this will help you
Cheers Beroli
Page 1 of 1 (5 items) | RSS
