The jukebox doesn't see the soundheart.the led on the back is white but it can not make a connection.
What have I done wrong?
Is this a first time set up or have you had it working previously?
I suggest powering everything off, including router and start again.
Opman
First time.
I think it's the internet connection.
Congrats, so you finally took the step towards a Moment.
Make sure your wireless is within reach of the Jukebox, it needs a good and strong signal.
"Believe nothing you read and only half of what you see, let your ears tell you the truth."
koning: The jukebox doesn't see the soundheart.the led on the back is white but it can not make a connection. What have I done wrong?
Hi Koning,
I did the easy first-start-setup by myself and crashed a wall only after 1 minute. Choose language - check, Country - check, keyboard -check, WLAN - check. "Sorry can not find the soundheart" - crash. After talking with my dealer, getting a replacement and crashing again at the same point - my dealer got a great idea. Maybe there is something wrong with your network. The solution was to change the 6 year old Name of my Network (e.g. "Lost & Found" to LostFound). The Soundheart can not link to the Jukebox, if your WLAN-Network-SSID includes any special charakters or spaces.
Hope this will help you
Cheers Beroli
