BeoNut since '75
Nice unboxing :)
elephant:Step 4 all is unwrapped and on display From the top ... BeoLink Converter NL/ML Essence Mk 2 Essence table top remote ML Power Box
From the top ...
Essence Mk 2
ML Power Box
hi elephant,
could you please post the little manual /sheet of paper from the ML Power Box. i have tried to zoom in it, but I can't read it.
Thank you in advance
Cheers Beroli
I'm sure you would enjoy the product a whole lot more if the packaging had been nicer... You know, more Apple like.
Jeff
BeoBoy68:Why B&O didn't use the nice BeoLink Converter design for the BeoSound Essence box ?!
Simply because the Essence is wifi, so this big aluminum plate is not good for wireless antennas. There is not such a problem with the converter as it doesn't have any kind of wireless antenna.
diisign.com
mbee: BeoBoy68:Why B&O didn't use the nice BeoLink Converter design for the BeoSound Essence box ?! Simply because the Essence is wifi, so this big aluminum plate is not good for wireless antennas. There is not such a problem with the converter as it doesn't have any kind of wireless antenna.
Doesn't work as an excuse for cheap design for max profit, you have phones like the iPhone and iPod's that work fine in metal. Even my macbook pro work. The idea! You only have to design antennabands or cut outs. You can even have the base in plastic for antennas. Just use a good designer instead of a generic white plastic box that could be your door bell.
Completely agree with Martin
Bang & Olufsen have no excuse.
The BeoSound Essence box is so ugly and cheap for the high price ( 675.-€ ) !
BeoBoy68:Completely agree with Martin Bang & Olufsen have no excuse. The BeoSound Essence box is so ugly and cheap for the high price ( 675.-€ ) !
Just for your information
Please watch this video found on internet.
Unboxing Devialet Phantom.
https://www.youtube.com/watch?v=EscN95Ubo38
The quality of the package and the magic box opening enchant your purchase.
Hoping,
B&O will change the design for the BeoSound Essence Mark III
@ elephant
Can you confirm us that the BeoSound Essence is made in Poland or Czech Republic ?
BeoBoy68:@ elephant Can you confirm us that the BeoSound Essence is made in Poland or Czech Republic ? Thanks
BeoBoy68: Just for your information Please watch this video found on internet. Unboxing Devialet Phantom. https://www.youtube.com/watch?v=EscN95Ubo38 The quality of the package and the magic box opening enchant your purchase.
And it mysteriously pulsates straight out of the box! I'm afraid that the aesthetics of the design do nothing for me.... it doesn't look like a high quality design or finish.
Graham
vikinger:And it mysteriously pulsates straight out of the box! I'm afraid that the aesthetics of the design do nothing for me.... it doesn't look like a high quality design or finish. Graham
Duels: vikinger: And it mysteriously pulsates straight out of the box! I'm afraid that the aesthetics of the design do nothing for me.... it doesn't look like a high quality design or finish. Graham It's a bit of an ugly bugger
Definitely nothing like Bang & Olufsen! Anyway; enough about dodgy, ugly speakers...
Back to the thread at hand!
x:________________________
Hi Ed, how did you get on with the NL/ML converter? Does it do the job it should?
Jonathan:Hi Ed, how did you get on with the NL/ML converter? Does it do the job it should?x:________________________
Have a look at the menu configuration / nl management. Here you can find all the NL sources and you can remove the ones you do not have.
Livius:Have a look at the menu configuration / nl management. Here you can find all the NL sources and you can remove the ones you do not have.
Oh no elephant! You appear to have...the Comfy Chair! Complete with the Soft Cushions! No one expects the...
