Jeff:Oh no elephant! You appear to have...the Comfy Chair! Complete with the Soft Cushions! No one expects the... Jeff Beovirus victim, it's gotten to be too much to list!
BeoNut since '75
elephant: Livius: Have a look at the menu configuration / nl management. Here you can find all the NL sources and you can remove the ones you do not have. Thank you Just the two items appear there - the E2 and the BCL
Thank you
Hi elephant,
Really, great thread
I did the NL/ML-Setup myself and yes it´s a little bit tricky. there is a link to the installation guide version 1.2 for the Beolink Converter NL/ML somewhere in this forum. It´s really usefull. Don´t forget to pull the powercord after every changes in the configuration. The BLC needs a restart to do the new settings. I removed some devices in the NL management myself and changed some settings and forgot to restart - in the end I shouted at the box. But mostly "The reason for failure is almost sitting in front of the device" . Don´t forget to update the software. The latest version from the BeoLink Converter NL/ML is 1.4.1.19311 from 11 June 2015. Have fun with the new Essence MK 2 and the BLC. Take care!
Cheers Beroli
Beroli:Hi elephant, Really, great thread I did the NL/ML-Setup myself and yes it´s a little bit tricky. there is a link to the installation guide version 1.2 for the Beolink Converter NL/ML somewhere in this forum. It´s really usefull. Don´t forget to pull the powercord after every changes in the configuration. The BLC needs a restart to do the new settings. I removed some devices in the NL management myself and changed some settings and forgot to restart - in the end I shouted at the box. But mostly "The reason for failure is almost sitting in front of the device" . Don´t forget to update the software. The latest version from the BeoLink Converter NL/ML is 1.4.1.19311 from 11 June 2015. Have fun with the new Essence MK 2 and the BLC. Take care! Cheers Beroli
BeoBoy68:The BeoSound Essence MK I Cardbox
mbee: BeoBoy68:Why B&O didn't use the nice BeoLink Converter design for the BeoSound Essence box ?! Simply because the Essence is wifi, so this big aluminum plate is not good for wireless antennas. There is not such a problem with the converter as it doesn't have any kind of wireless antenna.
Exactly why the Apple Time Capsule, Airport Express et all are made of plastic :-)
elephant, a really great thread - thanks for sharing the photos and nice to see the Beo Baby :-)
Raeuber:Hello elephant, it seems Essence Mk2 looks different to Mk1. Is it still possible to hang Mk2 on a wall? Regards Räuber
elephant:I don't recall the Mark 1's instructions. And your question prompted me to look at something I had discarded in my rush to get to the music I hope these photos help BeoNut since '75
Aussie Michael:elephant, a really great thread - thanks for sharing the photos and nice to see the Beo Baby :-)
i got matching packages :)
BeoBoy68:@ PK Really pity that the white box look so cheap
No it doesn't. It looks good
Well done PK
PK, could you test something for me? I'm nearing the purchase of a Essence and i'm wondering: In the BeoMusic app there is access to iOS music library. If used, the Essence wil play the selected music, but can you "join" this from another room?
I'm still troubled that Airplay does not distribute from say A9 to Essence, Yamaha and their new MusicCast does this fine..
L1NO: I'm still troubled that Airplay does not distribute from say A9 to Essence, Yamaha and their new MusicCast does this fine..
Please tell more:
Did you try the AirPlay distribution on the Yamaha-thingies out, or did you just read it?
If last one, where did you read it?
In an email from Yamaha they assure that they distribute any source externally but also the internal sources. Also they accept any blutooth hid device for control, so you can even hookup the essence wheel. Hook this up to an arduino IR translator and you have a verry cheap but much more capable receiver. The one touch 'join' is ofcourse better executed on b&o side. But why does the essence not distribute airplay again?
Let's say it so: I want to see (=hear) that, before I believe it.
I don't know of any case - besides from iTunes - that Apple allows for streaming to more than one device at the time.
L1NO:PK, could you test something for me? I'm nearing the purchase of a Essence and i'm wondering: In the BeoMusic app there is access to iOS music library. If used, the Essence wil play the selected music, but can you "join" this from another room?I'm still troubled that Airplay does not distribute from say A9 to Essence, Yamaha and their new MusicCast does this fine..
Millemissen:Let's say it so: I want to see (=hear) that, before I believe it. I don't know of any case - besides from iTunes - that Apple allows for streaming to more than one device at the time. MM There is a tv - and there is a BV.
Elephant, can I ask do you still have the mk1 essence as well, does this show up in the music app with the mk2?
I am asking as I have a mk1 essence and thinking of getting a mk2 and wondered how they would both work with the app as the mk1 is not able to join the multiroom.
thanks
Toby
Well, they accept airplay. And distribute this to other receivers or any of the sonos like speakers they make. So a single point airplay from ios to multiple receivers distributed trough utp.
badgersurf:Elephant, can I ask do you still have the mk1 essence as well, does this show up in the music app with the mk2? I am asking as I have a mk1 essence and thinking of getting a mk2 and wondered how they would both work with the app as the mk1 is not able to join the multiroom. thanks Toby
Aussie Michael:Well done elephant - is this itunes music stored on the actual device and or streaming from a different location? From what I understand of your post you are able to have a song in your itunes library streaming to multiple locations - something that in the past one has only been able to do when they stream from itunes on a computer and not on an ios device? Kind regards Michael.
elephant:Sorry Toby, I held off until now, so my first and only Essence is a Mark 2 and therefore multi-room link enabled-- and the new BLC is link enabled too. BeoNut since '75
However there is something tricky going on:-- iTunes tracks purchased by that device that are downloaded onto the device play-- Apple Music downloads don't play-- iTunes purchased by the family group owner appear not to play-- it may even be that MP3 rips by the family group owner don't playSo great when it works and as maddening as hell itself when you can see a grayed out track you are lusting to hear .....
elephant:Step 4 all is unwrapped and on display From the top ... BeoLink Converter NL/ML Essence Mk 2 Essence table top remote ML Power Box
From the top ...
Essence Mk 2
ML Power Box
If I order an Essence and a BeoLink converter, do I need to order the ML Poer Box also, or is that included with the converter?
Millemissen: Confirmed that I go multi link iOS tracks ....
I'm curious. What does the back button do? Can you 'ignore' the rotation of the device?
@L1NO
You are quoting me for something, that elephant answered on my request.
The first one he will have to answer.
The second one - no you can't ignore the rotation of the device.
Rotating gives you access to the two 'interfaces' of the app.
L1NO:I'm curious. What does the back button do? Can you 'ignore' the rotation of the device?
Razlaw:If I order an Essence and a BeoLink converter, do I need to order the ML Poer Box also, or is that included with the converter?
mjmedlo:You only need the ML Power box if you don't have an ML product
