Essence Mk 2 (et al) unpacked
This post has 77 Replies | 1 Follower
elephant
AU
Posts 8,219
elephant replied on Sat, Aug 29 2015 5:27 PM
Jeff:
Oh no elephant! You appear to have...the Comfy Chair! Complete with the Soft Cushions! No one expects the...
Jeff
Beovirus victim, it's gotten to be too much to list!
If I had panned left you would have seen ... Scatter Cushions !!!
At least no pipe nor slippers in sight Devil
PS I owe you a late PM, I only discovered it as part of using BeoWorld in the Mac ! 99.89% of the time I post via Philippe's app.
BeoNut since '75
Beroli
Germany
Posts 316
Beroli replied on Sat, Aug 29 2015 6:05 PM
elephant:
Livius:
Have a look at the menu configuration / nl management. Here you can find all the NL sources and you can remove the ones you do not have.
Thank you Smile
Just the two items appear there - the E2 and the BCL
Hi elephant,
Really, great thread
I did the NL/ML-Setup myself and yes it´s a little bit tricky. there is a link to the installation guide version 1.2  for the Beolink Converter NL/ML somewhere in this forum. It´s really usefull. Don´t forget to pull the powercord after every changes in the configuration. The BLC needs a restart to do the new settings. I removed some devices in the NL management myself and changed some settings and forgot to restart - in the end I shouted at the box. But mostly "The reason for failure is almost sitting in front of the device" Big Smile. Don´t forget to update the software. The latest version from the BeoLink Converter NL/ML is 1.4.1.19311 from 11 June 2015. Have fun with the new Essence MK 2 and the BLC. Take care!
Cheers Beroli
elephant
AU
Posts 8,219
elephant replied on Sun, Aug 30 2015 1:15 AM
Beroli:
Hi elephant,
I did the NL/ML-Setup myself and yes it´s a little bit tricky. there is a link to the installation guide version 1.2 for the Beolink Converter NL/ML somewhere in this forum. It´s really usefull. Don´t forget to pull the powercord after every changes in the configuration. The BLC needs a restart to do the new settings. I removed some devices in the NL management myself and changed some settings and forgot to restart - in the end I shouted at the box. But mostly "The reason for failure is almost sitting in front of the device" . Don´t forget to update the software. The latest version from the BeoLink Converter NL/ML is 1.4.1.19311 from 11 June 2015. Have fun with the new Essence MK 2 and the BLC. Take care!
Cheers Beroli
Thanks mate. It's good that we can have good debates and discussion while remaining friends and helping one another.
And now you mention cutting the power I remember that being mentioned.
But in my excitement I had completely forgotten !
BeoNut since '75
BeoBoy68
Alsace 🇨🇵
Posts 1,247
BeoBoy68 replied on Sun, Aug 30 2015 1:55 AM
The BeoSound Essence MK I Cardbox Yes - thumbs up
elephant
AU
Posts 8,219
elephant replied on Sun, Aug 30 2015 2:51 AM
BeoBoy68:
LaughingLaughingLaughing
BeoNut since '75
Raeuber
Germany
Posts 2,542
Raeuber replied on Sun, Aug 30 2015 8:11 AM
Hello elephant,
it seems Essence Mk2 looks different to Mk1. Is it still possible to hang Mk2 on a wall?
Regards
Räuber
Aussie Michael
Melbourne, AU
Posts 3,730
mbee:
BeoBoy68:
Why B&O didn't use the nice BeoLink Converter design for the BeoSound Essence box ?! SurpriseConfused
Simply because the Essence is wifi, so this big aluminum plate is not good for wireless antennas. There is not such a problem with the converter as it doesn't have any kind of wireless antenna.
Exactly why the Apple Time Capsule, Airport Express et all are made of plastic :-)
Aussie Michael
Melbourne, AU
Posts 3,730
elephant, a really great thread - thanks for sharing the photos and nice to see the Beo Baby :-)
elephant
AU
Posts 8,219
elephant replied on Sun, Aug 30 2015 11:20 AM
Raeuber:
Hello elephant,
Regards
Räuber
I don't recall the Mark 1's instructions.
And your question prompted me to look at something I had discarded in my rush to get to the music Big Smile
I hope these photos help
BeoNut since '75
vlohjr1
Posts 553
vlohjr1 replied on Sun, Aug 30 2015 12:39 PM
elephant:
BeoNut since '75
All I did for my mki was to use 3M command Velcro strips for wall fixing and they are as sturdy as hellWink
elephant
AU
Posts 8,219
elephant replied on Sun, Aug 30 2015 1:08 PM
Aussie Michael:
She's the Mark 2, Mark 1 has already made his appearance here some time ago Smile
BeoNut since '75
Mark
London
Posts 1,063
Mark replied on Mon, Aug 31 2015 2:16 PM
looks great Elephant
PK
Posts 82
PK replied on Wed, Sep 2 2015 6:37 PM
i got matching packages :)
PK
Posts 82
PK replied on Wed, Sep 2 2015 7:43 PM
BeoBoy68
Alsace 🇨🇵
Posts 1,247
@ PK
Good Choice Big Smile
Really pity that the white box look so cheap Sad
Aussie Michael
Melbourne, AU
Posts 3,730
BeoBoy68:
@ PK Really pity that the white box look so cheap Sad
No it doesn't.  It looks good
Well done PK
L1NO
Posts 250
L1NO replied on Sat, Sep 5 2015 3:27 PM
PK, could you test something for me? I'm nearing the purchase of a Essence and i'm wondering: In the BeoMusic app there is access to iOS music library. If used, the Essence wil play the selected music, but can you "join" this from another room?
I'm still troubled that Airplay does not distribute from say A9 to Essence, Yamaha and their new MusicCast does this fine..
Millemissen
Flensborg, Denmark
Posts 14,680
L1NO:
Please tell more:
Did you try the AirPlay distribution on the Yamaha-thingies out, or did you just read it?
If last one, where did you read it?
L1NO
Posts 250
L1NO replied on Sat, Sep 5 2015 9:18 PM
In an email from Yamaha they assure that they distribute any source externally but also the internal sources. Also they accept any blutooth hid device for control, so you can even hookup the essence wheel. Hook this up to an arduino IR translator and you have a verry cheap but much more capable receiver. The one touch 'join' is ofcourse better executed on b&o side. But why does the essence not distribute airplay again?
Millemissen
Flensborg, Denmark
Posts 14,680
Let's say it so: I want to see (=hear) that, before I believe it.
I don't know of any case - besides from iTunes - that Apple allows for streaming to more than one device at the time.
elephant
AU
Posts 8,219
elephant replied on Sun, Sep 6 2015 12:49 AM
L1NO:
I think I succeeded with this last night.
I will repeat this test later today.
BeoNut since '75
elephant
AU
Posts 8,219
Millemissen:
Confirmed that I go multi link iOS tracks ....
BeoNut since '75
elephant
AU
Posts 8,219
And also when using Susie's iPad Mini which happens to be running iOS 9 ...
BeoNut since '75
Aussie Michael
Melbourne, AU
Posts 3,730
Well done elephant - is this itunes music stored on the actual device and or streaming from a different location?
From what I understand of your post you are able to have a song in your itunes library streaming to multiple locations - something that in the past one has only been able to do when they stream from itunes on a computer and not on an ios device?
Kind regards
Michael.
badgersurf
Posts 539
Elephant, can I ask do you still have the mk1 essence as well, does this show up in the music app with the mk2?
I am asking as I have a mk1 essence and thinking of getting a mk2 and wondered how they would both work with the app as the mk1 is not able to join the multiroom.
thanks
Toby
L1NO
Posts 250
L1NO replied on Sun, Sep 6 2015 8:39 AM
Well, they accept airplay. And distribute this to other receivers or any of the sonos like speakers they make. So a single point airplay from ios to multiple receivers distributed trough utp.
elephant
AU
Posts 8,219
badgersurf:
thanks
Toby
Sorry Toby, I held off until now, so my first and only Essence is a Mark 2 and therefore multi-room link enabled-- and the new BLC is link enabled too.
BeoNut since '75
elephant
AU
Posts 8,219
Aussie Michael:
Kind regards
Michael.
It was from tracks or albums on the various iDevices.
However there is something tricky going on:
-- iTunes tracks purchased by that device that are downloaded onto the device play
-- Apple Music downloads don't play
-- iTunes purchased by the family group owner appear not to play
-- it may even be that MP3 rips by the family group owner don't play
So great when it works and as maddening as hell itself when you can see a grayed out track you are lusting to hear .....
BeoNut since '75
badgersurf
Posts 539
elephant:
Sorry Toby, I held off until now, so my first and only Essence is a Mark 2 and therefore multi-room link enabled-- and the new BLC is link enabled too. BeoNut since '75
Thanks Elephant, for some reason thought you had a mk1 as well.
Great post by the way and hope you get it all running smoothly
Regards
elephant
AU
Posts 8,219
elephant replied on Sun, Sep 13 2015 1:32 PM
In demonstrating the Apple Watch controlling the Essence I suddenly realised the Watch was talking via the Phone. I airplane moded the Phone and establish a direct connection from the Watch to the Essence.
I then carefully defined Bluetooth connections directly from the "source device" (Watch, iPad, iPhone, Mac) and found that now any device could stream Apple Music - no gaps.
I now feel I am in control the environment ... Until my wife Wales off with the opera playing phone in HR pocket, and the music died Big Smile
BeoNut since '75
Razlaw
Posts 4,345
Razlaw replied on Sun, Sep 13 2015 4:11 PM
elephant:
Step 4 all is unwrapped and on display
From the top ...
Essence Mk 2
Essence table top remote
ML Power Box
If I order an Essence and a BeoLink converter, do I need to order the ML Poer Box also, or is that included with the converter?
L1NO
Posts 250
L1NO replied on Sun, Sep 13 2015 4:27 PM
Millemissen:
I'm curious. What does the back button do? Can you 'ignore' the rotation of the device?
L1NO
Posts 250
Millemissen:
Millemissen
Flensborg, Denmark
Posts 14,680
@L1NO
You are quoting me for something, that elephant answered on my request.
The first one he will have to answer.
The second one - no you can't ignore the rotation of the device.
Rotating gives you access to the two 'interfaces' of the app.
elephant
AU
Posts 8,219
elephant replied on Sun, Sep 13 2015 10:37 PM
L1NO:
In portrait mode the back button takes you back to the source screen without trying to rotate the device.
To select the linking/joining screen press the link symbol.
You then get a portrait view with text at 90 degrees.
Pressing back takes you back.
No rotations required - other than turning your head sideways to read ....
Note that the photo below is rotated although in real life my iPhone was not !
BeoNut since '75
mjmedlo
Posts 922
mjmedlo replied on Mon, Sep 14 2015 12:08 AM
Razlaw:
You only need the ML Power box if you don't have an ML product
elephant
AU
Posts 8,219
elephant replied on Mon, Sep 14 2015 12:50 AM
mjmedlo:
I.E. If you only have ML link room speakers like 3500 and 2000.
BeoNut since '75
Razlaw
Posts 4,345
Razlaw replied on Mon, Sep 14 2015 1:24 AM
mjmedlo:
Thanks!
Page 2 of 2 (78 items) < Previous 1 2 | RSS
