BeoGreg:Impossible to update. I follow the instructions (plug mini usb, press + - and power, must flash red wich it doesn't if usb connected, press continue). Nothing happens, when I get the chance to have a ref flashing light it's for two seconds and it makes a noise of usb disconnection. Frustrating and fed up !
Did you try to press first + - and keep pressing and then press power for few seconds?
Do you want to sell it? If so, what do you want for it?
