As revealed on the "Essence Mk 2 (et al) unpacked" thread I have acquired both an Essence Mk 2 and a BCL NL/ML.
I have even installed the recommended (subnet) switch.
And I have the Essence and the BLC working.
However I am having to fudge the system to get the Essence's music across into my ML world.
And I am going around the twist trying to get the right BCL settings.
So I would appreciate some advice
This is my configuration on the ML side:
> BeoPort -- answers to/sources N-Music (and N-Radio which actually is broken inside iTunes these days)
> BeoSound 4 -- answers to/sources CD, RADIO, A-AUX, A-MEM
> BeoVision 8 --answers to/sources TV, DTV, DVD, DVD-2, PC
So how should I set up the BLC so that the ML side can access the Essence as a source ?
I don't have any speakers on the BLC, nor an IR-eye.
BeoNut since '75
elephant:As revealed on the "Essence Mk 2 (et al) unpacked" thread I have acquired both an Essence Mk 2 and a BCL NL/ML. I have even installed the recommended (subnet) switch. And I have the Essence and the BLC working. However I am having to fudge the system to get the Essence's music across into my ML world. And I am going around the twist trying to get the right BCL settings. So I would appreciate some advice This is my configuration on the ML side: > BeoPort -- answers to/sources N-Music (and N-Radio which actually is broken inside iTunes these days) > BeoSound 4 -- answers to/sources CD, RADIO, A-AUX, A-MEM > BeoVision 8 --answers to/sources TV, DTV, DVD, DVD-2, PC So how should I set up the BLC so that the ML side can access the Essence as a source ? I don't have any speakers on the BLC, nor an IR-eye. BeoNut since '75
Must work also with Essence:
Software-version:
Setup:
"Believe nothing you read and only half of what you see, let your ears tell you the truth."
mjmedlo:Even with no IR you still have to tell the nl/ml convertor what ir to look for. Apparently that's how part of the internal workings. What sources do you want to carry from one place to another
elephant:The power recycle tip helped me test various configurations. However it was a day of frustration compounded by me NOT recording my steps and options and results. 👞 kick 🐘 myself Anyway, at one stage somehow in enabled LineIn on the BLC and that meant Essence music was playing on the BV8 ... now I have lost that configuration On the other hand right now I have a configuration where the Essence can play BeoSound music and BeoVision channels (of course no video ) My challenge given that I have on the ML side a BS, a BV, and a BeoPort is what role to allocate to the BLC so sources and commands can pass in both directions ! BeoNut since '75
mjmedlo:Source center
I have now got some strange problems that accured on my multiroom system. After the final update i can't longer get multiroom to work. It show's up in the Beomusic app, but nothing happens when i push on V1. It doesn't show "link" button on my Moment. But i can use the join button on my remote.. A man from BO was here today for many hours, with support from a man in BO, but couldn't figure it out.
Everything is connected thru an BLC and i have a BV10..
Strange
Normann:A man from BO was here today for many hours, with support from a man in BO, but couldn't figure it out.
This is a joke, no it is't.
There are some serious problems (bugs) with the latest update for the Moment, especially with multiroom use.
This is happening to me:
- no response from track up-down buttons on my beo4 remote anymore, when I use Moment and a ML product only. When I use an ML product and a NL product together in multiroom it suddenly works again.
- After playing 27 tracks in multiroom music stops playing, ML product goes to standby, NL product stays on and Moment also.
I'm waiting now for a week to get response from Beocare, because my dealer looks at me 'Why you again'.
Chris: Normann:A man from BO was here today for many hours, with support from a man in BO, but couldn't figure it out. This is a joke, no it is't.
Sadly it ain't a joke..
Eclipse 65V1-32Beosound M5Essence MK2BLI
Exactly
elephant:Still attempting to perfect my configuration. Perfection = bi-directional sources; something seemed not to work with "Source Centre". I still think I lack an understanding of the fundamental concept(s) of the Beo Link Converter NL/ML *sigh* However I have found how to do Factory Resets (and boy is it complicated!!) ... Woo hoo BeoNut since '75
Maybe elephant likes the challenge of setting it up himself.
Much 'entertainment' for the money 😄
Maybe it is not driving him 'mad', but 'BeoNuts'.
Raeuber:There are 9 days gone after unpacking the converter and it's still not working perfect? Seems to be like buying a puzzle with 10.000 pieces. The fundamental concept of this product is simply driving you mad! Regards Räuber
Raeuber: There are 9 days gone after unpacking the converter and it's still not working perfect? Seems to be like buying a puzzle with 10.000 pieces. The fundamental concept of this product is simply driving you mad! Regards Räuber
Regards
Räuber
Hush Räuber - his testing and experiences might become helpfull to you sometime in the future.
Seanie_230:I have also noticed your remote issue. From the v1 forward and back track ship has stopped working.
I've got response from Beocare to this, for me fundamental problem.
They forwarded it to the R&D department
Giraffe:Hi Elephant, did you come to a final working configuration that you can share? I'm facing a similar challenge like you with the following config: Living room: - BV11 plus speakers - BS3000 - BS Moment Bedroom: - BV10 I also would like to add speakers to the BLC for the office in the near future. I'm in particular struggling with selecting the right ML mode for the BLC. A not so-nice side effect is that whenever I select a source of the Moment in a link room, the BV11 in the living room turns on, too, because the moment shares speakers with the BV11. Not using shared speakers isn't really an option because I would have to switch on the TV manually if I start playing music on the Moment. This probably is not applicable to your setup but maybe others have a hint here. Best, Giraffe
Giraffe:Thanks Elephant - first tests today look promising! I can now select BS3000 or BV10 sources, as well as the Moment's sources on all devices. However, I did not manage to let my BV10 join the sound from the Moment via BeoMusic app - needs some more investigation. Best, Giraffe
Giraffe:However, I did not manage to let my BV10 join the sound from the Moment via BeoMusic app - needs some more investigation.
I´m quite sure that the Beomusic app will not "talk" to any of equipment on the "ML-side" of the BLC.
You can only use Beomusic app to e.g. switch off the ML connected units (by clicking the X in the tile for BLC), and that will be all units on the ML side.
I have Beolab 3500 and Beolab 2000 on ML side, and thats the only thing I can do with them using the Beomusic app.
/C
Livingroom: BL3, BL11, BV11-46 Kitchen: Beosound 1 GVA, Beocom 2 Bathroom: M3 Homeoffice: M3, Beocom 2 Library: Beosound Emerge, Beocom 6000 Bedroom: M5, Essence remote Travel: Beoplay E8 2.0, Beoplay EQ, Beoplay Earset
