Penta - trim coming away
This post has 3 Replies | 0 Followers
Mark
London
Posts 1,063
Mark Posted: Tue, Jun 19 2012 2:27 PM
Hi All
Any ideas on how I can repair the top of my Penta 3 speaker ? the aluminium top is lifting at one corner and although does not seem to alter the performance (as far as my blasted ears can tell) it looks unsightly.
thanks in advance
joeyboygolf
Ely, Cambridgeshire, UK
Posts 4,188
It is only decoration which is held on by double sided tape. Replace the tape,  is the answer.
Regards Graham
casdave
Posts 16
casdave replied on Tue, Jun 19 2012 8:47 PM
Some of it is double sided tape, but other parts are glued with a substance similar to No-nails
Steffen
Denmark
Posts 1,408
Steffen replied on Wed, Jun 20 2012 12:54 AM
I've had the same problem with the top-plates on my Penta's. I just gave it some Super-glue and put something heavy on top until the glue had dried.
They will never loosen again Big Smile
Page 1 of 1 (4 items) | RSS
