Hi All
Any ideas on how I can repair the top of my Penta 3 speaker ? the aluminium top is lifting at one corner and although does not seem to alter the performance (as far as my blasted ears can tell) it looks unsightly.
thanks in advance
It is only decoration which is held on by double sided tape. Replace the tape, is the answer.
Regards Graham
Some of it is double sided tape, but other parts are glued with a substance similar to No-nails
I've had the same problem with the top-plates on my Penta's. I just gave it some Super-glue and put something heavy on top until the glue had dried.
They will never loosen again
