Hi.
Can anyone tell me if they have connected a BS Moment thru a BLC, to another ML product, that you can choose "link" on the soundheart on Moment?
Normann:Hi. Can anyone tell me if they have connected a BS Moment thru a BLC, to another ML product, that you can choose "link" on the soundheart on Moment?
mjmedlo: Normann: Hi. Can anyone tell me if they have connected a BS Moment thru a BLC, to another ML product, that you can choose "link" on the soundheart on Moment? I haven't gotten this to show up I'm using he BeoMusic App to port it around.
Ok.?? I have problem to make it work with the Beomusic App.. The linked rooms are shown, but nothing happens when i push the buttons.. But i can push "join" on my Beo4 remote and bring the music.. But again, that is not how it should work.
mjmedio: Can you port around to other "ML room/products" also, or just to the NL products.?
I believe the only way to do this is a separate ML/NL converter for every legacy product.
I've chosen to use 'join' on the ML products (or associate a command).
I also use the gateway for this.
I would suggest a power cycle of the ML/NL converter and delete then reinstall the app.
sometimes i've found that the app doesn't refresh as often as I'd like and will look for things
on the network that are no longer there.
MJM
mjmedlo:I believe the only way to do this is a separate ML/NL converter for every legacy product.
BeoNut since '75
elephant:Hmmmm In my finally working setup (and Thank You! For Your advice) I find I can not shut down the N-RADIO on the BeoSound 4 ... Not on the BeoSound4 ... Not on the App ... Not on the Beo4 ... Not on my Essence And changing sources has no effect Does this mean I need a second BLC ? BeoNut since '75
mjmedlo:I don't hunk I understand? If you select all standby it won't turn off? You may have one of the NL products selecting N.Music on button press?
elephant:Correct ... None of the standbys work And yes, N.Radio is linked to TuneIn, and N.Music is linked to Music which I believe is related whatever music stream was playing last e.g. AirPlay I was about to show my configuration settings and I spotted an anomaly (as an aside I find you have to triple check that changes on BLC menu don't undo settings on an earlier menu) So I set out to rectify that ... and in the process did a factory reset by accident *sigh* Now I have to rebuild the configuration .... *SIGH* BeoNut since '75
mjmedlo: I believe the only way to do this is a separate ML/NL converter for every legacy product. I've chosen to use 'join' on the ML products (or associate a command). I also use the gateway for this. I would suggest a power cycle of the ML/NL converter and delete then reinstall the app. sometimes i've found that the app doesn't refresh as often as I'd like and will look for things on the network that are no longer there. MJM
Would you recomend me to buy a beolink converter to get fully functional ML/NL system?
Do you currently have one beolink converter in place?
it is on your network that then gets distributed out to the legacy products correct?
so the NL goes in to the converter, then the ML goes from the converter to the legacy products?
if that's the set up. . then you should have local control. . i.e. you should be able to use the remotes
I have not hook my BLC directly to any one particular legacy product. I'm inclined to think it will NOT turn on your beosound 4. It might operate the link speakers though.
Honestly, I don't know.
If you decide to connect the BLC masterlink only to one legacy product please report back. I'd love to know the results.
