Beosound Moment Questions
This post has 7 Replies | 0 Followers
Razlaw
Posts 4,345
Razlaw Posted: Sat, Sep 12 2015 1:49 PM
Sorry for starting a new thread but I have tried three times, yesterday and today to post these questions in two different threads and have been blocked as moderated each time. So I am trying to post as a new thread.
The Moment was recently made available in the US and I am considering one. However I am somewhat confused about how it would work with my system and have some questions. I hope someone does not mind answering them.
I have a BV7-55 with attached speakers and a BV10-40 with attached speakers. They are connected with Masterlink along with a Beosound 5. There is another Masterlink connection available in a third room which is where my router is  I also have a stand alone Beoplay V1.
My questions are:
1. Do I need one or two NetLink converters to be able to access the Moment through the BV7/speakers and BV10/speakers?
2. Does/do the converter(s) need to be connected to the BVs,  or if only one is needed, could I connect it to the Masterlink in the third room?
3. Once the Moment is connected, if I wish to listen to music, must I turn the Moment using the Moment, or can I use the Beo 4 to turn music on as I do with the Beosound  5?
4. Will the Beoplay V1 connect in any manner wirelessly to the Moment or will the two remain completely separate?
5. Any comments on sound quality of Spotify on the Beosound 5 compared to Deezer on the Moment?
6. I have heard that in a couple months Deezer will make Elite available to all Deezer subscribers, not just those with Sonos system. Is this true?
Thank you in advance.
elephant
AU
Posts 8,219
elephant replied on Sun, Sep 13 2015 7:13 AM
Razlaw:
Interesting the the "One month with the Moment" thread (19 pages long) now crashes my iPad and PhilLondon's beoworld tool ....
Razlaw:
The Moment was recently made available in America However I am s confused about how it would work with my equipment and have some questions. I hope someone does not mind answering them.
Beovision7-55 with attached speakers and a Bevision10-40 with attached speakers. They are connected with Masterlink along with a Beosound 5. There is another Masterlink connection available in a third room which is where my router is I also have a Beoplay V1.
Is the third room with the router be what B&O terms "the technical room" (ie wiring closet) ?
Razlaw:
My questions are:
I believe one ... And if we were talking about an Essence rather than a moment I would suggest putting the Essence and the BLC into the "technical room"
Razlaw:
2. Does a converted need to be connected directly to theBeoviions or if only one is needed, could I connect it to the Masterlink in the third room?
In my opinion, as above, you need only one BLC.
Razlaw:
I lack the experience ... with my Essence I can start music with the Beo4 and then use the BeoMusic App to "join" the Essence to pick up the ML source
Razlaw:
I believe you should be able to do something with the V1 ... I think it was Chris who has that configuration ?
Razlaw:
5. Any comments on sound quality of Spotify on the Beosound 5 compared to Deezer?
Pass
Razlaw:
Pass
Razlaw:
Pleasure
BeoNut since '75
Razlaw
Posts 4,345
Razlaw replied on Sun, Sep 13 2015 2:29 PM
Thank you very much. I am beginning to think I should look at the Essence more seriously than I have been.
I suppose you could call the third room the technical room. It is where my desk top computer is, router, internet connection, etc are all located
If I am understanding correctly I could connect the Essence there along with a Net Link Converter and then everything should work.
Another question: I believe I have read that with NL there is no Audio Master. I have disconnected my Beosound 3000 as I was never able to get it to function correctly with the Beosound 5 in the system. With the Essence or Moment, and NL, if no Audio Master, should I be able to have both the Beosound 5 and Beosound 3000 connected to the system?
Sal
California, USA
Posts 1,197
Sal replied on Sun, Sep 13 2015 3:40 PM
Razlaw:
Me too.
I've just been checking the specifications, and the fact that the Moment doesn't have airplay was surprising to me. I know these two systems aren't geared for the same type of listener, but it seems like a slight omission for the Moment not to have all the specs that the Essence has.
Razlaw
Posts 4,345
Razlaw replied on Sun, Sep 13 2015 3:54 PM
If I am looking at things correctly, either the Moment or Essence would provide the same functions. Only differences I see is with the Moment there is the wood/touch screen controller so with the Essence would lose that, including the mood wheel but still have full control through the app. And with the Essence, still get Spotify which is what I am using now, in addition to Deezer, whereas the Moment only offers Deezer.
Sal
California, USA
Posts 1,197
Sal replied on Sun, Sep 13 2015 5:26 PM
Unless I missed it somewhere, I still don't see AirPlay capability with the moment.
As you point out though, the moment would be a dedicated and tactile music system -- which can be controlled via beomusic app, so theoretically, I can play music from the app through the moment, correct? Is that via Bluetooth or some other protocol?
I guess the question is whether the moment also handles AirPlay and whether Spotify will come to the moment?
Razlaw
Posts 4,345
Razlaw replied on Sun, Sep 13 2015 6:04 PM
I do not see Airplay as available either.
Millemissen
Flensborg, Denmark
Posts 14,680
No (native) AirPlay on the Moment .
Connect a Playmaker to the 'line-in' - then you'll can have AirPlay in your setup...and still have a 'line-in' free.
Page 1 of 1 (8 items) | RSS
