NO sound with overture and Beolab 3500
This post has 13 Replies | 2 Followers
olanilsson99
Posts 8
olanilsson99 Posted: Mon, Sep 14 2015 8:30 AM
I don´t get any sound with my BEO Overture and my Beolab 3500, I connect them by Masterlink, the clock is OK, and i can manage the volume, but there are NO sound at all. i have tryed different option on the Beolab 3500, and i have tryed to change the masterlinkcable.  Can anyone help me?
//ola
riverstyx
SouthWest UK
Posts 938
riverstyx replied on Mon, Sep 14 2015 1:19 PM
Hi and welcome to beoworld.
So we can be clear on what you are trying to achieve, can you advise whether you also have other speakers directly connected to the ouverture or if you are trying to utilise the beolab 3500 as your only speaker?
Kind regards,
Martin.
olanilsson99
Posts 8
Hi!
I Have the beolab that are included to the overture installed, they have sound, i have tryed both to unconnect them, and connected. still no sound in the "3500"
stefan
200 miles from Struer
Posts 2,920
stefan replied on Mon, Sep 14 2015 2:16 PM
Check:
1- press and hold stdby in the BL3500 room (linkroom). Now press RADIO - does Ouverture and BL3500 start up in RADIO mode?
2- if not, set the ouverture to A.OPT 1, BL3500 set to L.OPT 5. Try again 1...(?)
3- if this doesn`t help, checl ML cable (you have the clock? And BL3500 responds to volume commands?
4- next disconnect both units from the mains, wait a few minutes, reconnect them - first BL3500, 2nd Ouverture.
Hope this helps
Stefan
olanilsson99
Posts 8
Check:
1- press and hold stdby in the BL3500 room (linkroom). Now press RADIO - does Ouverture and BL3500 start up in RADIO mode? CHECK! YES but no sound
2- if not, set the ouverture to A.OPT 1, BL3500 set to L.OPT 5. Try again 1...(?) CHECK! helps not.
3- if this doesn`t help, checl ML cable (you have the clock? And BL3500 responds to volume commands? CHECK!
4- next disconnect both units from the mains, wait a few minutes, reconnect them - first BL3500, 2nd Ouverture. CHECK!
Sorry, nothing helps, i have tryed this.
The display on the 3500 responds the clock is OK, the display show´s what iám doing, like "cd" or "radio" i can see when i raise the volume, but no sound.......:-(
olanilsson99
Posts 8
Check:
stefan
Posts 2,920
stefan replied on Mon, Sep 14 2015 2:50 PM
olanilsson99:
So your Ouverture is set to A.OPT 1 ?
olanilsson99:
When you change the volume level, BL3500 should display the level like 22 - 24....and it shouldn`t show CD - RADIO....
Are you sure the ML board is still present in your audiosystem?
Again: when both units are activated and you press/hold stdby, will the whole system go to standby mode?
Stefan
olanilsson99
Posts 8
1. correct, the soundlevel shows like you say
2. If i press meny meny 02, it say´s ML activated
3. Yes, both system goes down.
Carolpa
Posts 1,700
Silver Member
Carolpa replied on Mon, Sep 14 2015 3:21 PM
It did work before or is it a new set-up?
Was the BL3500 used before as ML or as MCL product?
Isn't the BL3500/LCS9000 set to MCL instead of ML?
Carolpa
Posts 1,700
Silver Member
double post
olanilsson99
Posts 8
Hi!
1. The 3500 is new for me, the seller said that i worked
2. I don´t know what they used it for before me?
3. I don´t know this?
Regards
stefan
Posts 2,920
stefan replied on Mon, Sep 14 2015 3:32 PM
olanilsson99:
Which does not mean that a ML board is in the Ouverture...
olanilsson99:
This tells us a working ML board is present...
I`d check the audio wiring. ML uses a balanced signal, which requires three wires per channel.
You will find wiring diagram on beotech site.
Stefan
olanilsson99
Posts 8
I use an brand new ML cable, i have also tested another cable.
olanilsson99
Posts 8
Tack för all hjälp, tyvärr hjälpte det inte så jag har lämnat in den på service, hoppas att dom kan hitta felet :-)
Page 1 of 1 (14 items) | RSS
