I don´t get any sound with my BEO Overture and my Beolab 3500, I connect them by Masterlink, the clock is OK, and i can manage the volume, but there are NO sound at all. i have tryed different option on the Beolab 3500, and i have tryed to change the masterlinkcable. Can anyone help me?
//ola
Hi and welcome to beoworld.
So we can be clear on what you are trying to achieve, can you advise whether you also have other speakers directly connected to the ouverture or if you are trying to utilise the beolab 3500 as your only speaker?
Kind regards,
Martin.
Hi!
I Have the beolab that are included to the overture installed, they have sound, i have tryed both to unconnect them, and connected. still no sound in the "3500"
Check:
1- press and hold stdby in the BL3500 room (linkroom). Now press RADIO - does Ouverture and BL3500 start up in RADIO mode?
2- if not, set the ouverture to A.OPT 1, BL3500 set to L.OPT 5. Try again 1...(?)
3- if this doesn`t help, checl ML cable (you have the clock? And BL3500 responds to volume commands?
4- next disconnect both units from the mains, wait a few minutes, reconnect them - first BL3500, 2nd Ouverture.
Hope this helps
Stefan
1- press and hold stdby in the BL3500 room (linkroom). Now press RADIO - does Ouverture and BL3500 start up in RADIO mode? CHECK! YES but no sound
2- if not, set the ouverture to A.OPT 1, BL3500 set to L.OPT 5. Try again 1...(?) CHECK! helps not.
3- if this doesn`t help, checl ML cable (you have the clock? And BL3500 responds to volume commands? CHECK!
4- next disconnect both units from the mains, wait a few minutes, reconnect them - first BL3500, 2nd Ouverture. CHECK!
Sorry, nothing helps, i have tryed this.
The display on the 3500 responds the clock is OK, the display show´s what iám doing, like "cd" or "radio" i can see when i raise the volume, but no sound.......:-(
olanilsson99: 2- if not, set the ouverture to A.OPT 1, BL3500 set to L.OPT 5. Try again 1...(?) CHECK! helps not. 4- next disconnect both units from the mains, wait a few minutes, reconnect them - first BL3500, 2nd Ouverture. CHECK!
So your Ouverture is set to A.OPT 1 ?
olanilsson99: Sorry, nothing helps, i have tryed this. The display on the 3500 responds the clock is OK, the display show´s what iám doing, like "cd" or "radio" i can see when i raise the volume, but no sound.......:-(
When you change the volume level, BL3500 should display the level like 22 - 24....and it shouldn`t show CD - RADIO....
Are you sure the ML board is still present in your audiosystem?
Again: when both units are activated and you press/hold stdby, will the whole system go to standby mode?
1. correct, the soundlevel shows like you say
2. If i press meny meny 02, it say´s ML activated
3. Yes, both system goes down.
It did work before or is it a new set-up?
Was the BL3500 used before as ML or as MCL product?
Isn't the BL3500/LCS9000 set to MCL instead of ML?
double post
1. The 3500 is new for me, the seller said that i worked
2. I don´t know what they used it for before me?
3. I don´t know this?
Regards
olanilsson99: 2. If i press meny meny 02, it say´s ML activated
Which does not mean that a ML board is in the Ouverture...
olanilsson99: 3. Yes, both system goes down.
This tells us a working ML board is present...
I`d check the audio wiring. ML uses a balanced signal, which requires three wires per channel.
You will find wiring diagram on beotech site.
I use an brand new ML cable, i have also tested another cable.
Tack för all hjälp, tyvärr hjälpte det inte så jag har lämnat in den på service, hoppas att dom kan hitta felet :-)
