Hi, I was wondering if it is possible to buy two S8 system's and use them as a 4.2 system in place of getting beolab 14? Not only would it be cost effective, the sound quality would be better with two subwoofers. The only problem is that if it is possible to hook up the two system's with the a an a/v receiver using the preouts or through the cable used in beolab 14?
Update: The price difference is about £800!
Suggestions would be much appreciated
In UK: 2 S8s cost £1700(from amazon) and beolab 14 costs £2500. So a massive difference of £800. In the US the difference is $4000 - $2400 = $1600.
leosgonewild:I tried the S8 sub, and j didn't like it. I did not play around too long with the settings though. The Beolab 2 is avaliable for around 650-800£ second hand. If you want a serious home cinema, I think most people here would recommend Beolab 2 or 19 as they can be used for demolition.
Could you elaborate on this? I have not heard the S8 but have been tempted to buy it in case I decide to sell my BL9´s. I could then move my BL8000 to fronts and use the satellites as surround and the sub for the bass. Doesn't the S8 sub sound good? I don't know why but I thought the subwoofer would be quite good .
Beolab 50, Beolab 8000 x 2, Beolab 4000 x 2, BeoSound Core, BeoSound 9000, BeoSound Century, BeoLit 15, BeoPlay A1, BeoPlay P2, BeoPlay H9 3rd Gen, BeoPlay H6, EarSet 3i, BeoVision Eclipse Gen 2 55", BeoPlay V1-40, BeoCom 6000 and so much else :)
leosgonewild: I think most people here would recommend Beolab 2 or 19 as they can be used for demolition.
'Demolition' = 'The act or process of wrecking or destroying,especially destruction by explosives.'
I see there is need for a whole new B&O subbrand: B&O Bang 💣💥
@rob08
Do you just use the sub, or the 2.1 set?
Thanks!
Where are the advantages (compared to the BL11) - with music or movies, or with both?
Do you use different settings for music respectively movies?
Millemissen:Thanks! Where are the advantages (compared to the BL11) - with music or movies, or with both? Do you use different settings for music respectively movies? MM There is a tv - and there is a BV.
