Use 2 Beoplay S8 in place of beolab 14 and save £800?
This post has 15 Replies | 1 Follower
sid24
Posts 12
sid24 Posted: Tue, Sep 15 2015 9:50 AM
Hi, I was wondering if it is possible to buy two S8 system's and use them as a 4.2 system in place of getting beolab 14? Not only would it be cost effective, the sound quality would be better with two subwoofers. The only problem is that if it is possible to hook up the two system's with the a an a/v receiver using the preouts or through the cable used in beolab 14?
Update: The price difference is about £800!
Suggestions would be much appreciated
rob08
Posts 209
rob08 replied on Tue, Sep 15 2015 9:55 AM
Doesn't 2 S8 systems cost the same as 1 BL14.1?
sid24
Posts 12
sid24 replied on Tue, Sep 15 2015 10:09 AM
In UK: 2 S8s cost £1700(from amazon) and beolab 14 costs £2500. So a massive difference of £800. In the US the difference is $4000 - $2400 = $1600.
leosgonewild
Helsinki, Finland
Posts 2,373
The 14 is massively overpriced. Sad
rob08
Posts 209
rob08 replied on Tue, Sep 15 2015 6:17 PM
Wow, here in Sweden the price of the 4.1 BL14 is essentially the same as 2 S8
BillC
Posts 121
BillC replied on Wed, Sep 16 2015 4:42 AM
Just out of interest, is the sound quality of the S8/14 good? I don't have golden ears but the last time I heard them I thought it was rather good.
I'm trying to get a central for my surround sound and am currently using 2x Beolab 18, 2x beolab 3, 1 x beolab 3 (broke a pair for the centre) and a sub I bought before I went into B&O.
I'd also like to try and do a Dolby Atmos and maybe try the S8/14 for the ceiling.
I'm kinda of worried that the S8/14 wouldn't match well with the Beolab 18. It's a pity I didn't get into the surround sound until after B&O stopped making the centre speakers
leosgonewild
Helsinki, Finland
Posts 2,373
I tried the S8 sub, and j didn't like it.
I did not play around too long with the settings though.
The Beolab 2 is avaliable for around 650-800£ second hand.
If you want a serious home cinema, I think most people here would recommend Beolab 2 or 19 as they can be used for demolition.
Duels
England
Posts 2,553
Duels replied on Wed, Sep 16 2015 9:50 AM
The BL2 and 19 are amazing for movies. I guess for some the S8 might be more neighbour friendly depending on the level of sound insulation between properties.
Michael
Sweden
Posts 2,578
Michael replied on Wed, Sep 16 2015 10:24 AM
leosgonewild:
Could you elaborate on this? I have not heard the S8 but have been tempted to buy it in case I decide to sell my BL9´s. I could then move my BL8000 to fronts and use the satellites as surround and the sub for the bass. Doesn't the S8 sub sound good?
I don't know why but I thought the subwoofer would be quite good .
Millemissen
Flensborg, Denmark
Posts 14,680
leosgonewild:
'Demolition' = 'The act or process of wrecking or destroying,especially destruction by explosives.'
I see there is need for a whole new B&O subbrand: B&O Bang 💣💥
M😺M
rob08
Posts 209
rob08 replied on Wed, Sep 16 2015 10:45 AM
I have the BL14 sub only connected to my BV11 and it's great for movies. Big step up from the BL11. I live in an apartment so the BL14 is perfect for that
Millemissen
Flensborg, Denmark
Posts 14,680
@rob08
Do you just use the sub, or the 2.1 set?
rob08
Posts 209
rob08 replied on Wed, Sep 16 2015 11:08 AM
Just the sub and internal speakers in BV11
Millemissen
Flensborg, Denmark
Posts 14,680
Thanks!
Where are the advantages (compared to the BL11) - with music or movies, or with both?
Do you use different settings for music respectively movies?
jans
Belgium
Posts 394
jans replied on Wed, Sep 16 2015 11:33 AM
Michaël
I would do it the other way round: keep the BL9 and sell the 8K. Makes more sense to me.
rob08
Posts 209
rob08 replied on Wed, Sep 16 2015 2:23 PM
Millemissen:
Thanks!
The main advantage is that you really feel the bass in movies. The BL11 was in my view too weak and it it was seldom I noticed it during movies (this may also be a testament to the quality of the built in speakers of BV11).
I haven't tried it with much music. Typically doesn't listen to music via the TV.
Page 1 of 1 (16 items) | RSS
