Hi Paolo,
I'm sure that you can play UHD Blu-Ray on your Avant, you probably just won't be able to get the best from it as the Avant just has a basic panel and is not HDR equipped etc. or OLED so a bit old / outdated really.
Netflix seem to be truly ahead in the field so expect them to be working with HDR.
Means - if you want HDR content, you will have to go the Amazon or the UHD/Bluray way.
Or find one of the few movie theaters, that can show HDR movies.
Chris Townsend:More HDR info. https://www.avforums.com/article/ultra-hd-alliance-talks-4k-hdr-and-the-future-of-television.11916 Exciting stuff Beovision 7-55 Mk2, Beovision 8-32, Avant RF 28, Beolab 9, Beolit 15, Beoplay A2, Beocom 2, Beotime, H6, Form 2.
