I'm tearing my hair out here this morning! I'm going to phone B&O customer service as these speakers seem to have a mind of their own now.
Sometimes they autosense line-in, sometimes (most times) they don't). Sometimes they sense the input and play for about 2 seconds then switch off!
They are not picked up by the Beomusic app which seems a bit stupid.
When in power save satndby (double press B&O logo - no white light), Bluetooth is automatically disconnected but then autosense obviously won't work, but neither does the line-in. They are effetcively switched off until you manually switch them on again.
When they do come on using autosense, one speaker starts and then the other follows about 2 seconds later.
When starting music, there is a 3 second delay in sound coming out so you miss the start of the first track. I've not found this with other Bluetooth devices I have. The current behaviour of these leads me to believe that either I have a faulty pair, or, B&O have rushed these out without fully testing them, or, I have a problem with all of my sources (iPod, iPad Air2) My guess is one of the first two. I'm not a happy bunny this morning after having so much enthusiasm for these. They sound lovely when they work but seem to be a practical nightmare in use.
I'll let you know how it goes with customer serice.
Dave.
Dave Farr: They are not picked up by the Beomusic app which seems a bit stupid. Dave.
Please don't expect that!
The S3 is a bluetooth speaker, not a NL-enabled product.
The BeoMusic is a control app for NL-enabled devices - and it has no playback of it's own, that could be streamed via bluetooth.
Dave Farr:I'm tearing my hair out here this morning! I'm going to phone B&O customer service as these speakers seem to have a mind of their own now. Sometimes they autosense line-in, sometimes (most times) they don't). Sometimes they sense the input and play for about 2 seconds then switch off! They are not picked up by the Beomusic app which seems a bit stupid. When in power save satndby (double press B&O logo - no white light), Bluetooth is automatically disconnected but then autosense obviously won't work, but neither does the line-in. They are effetcively switched off until you manually switch them on again. When they do come on using autosense, one speaker starts and then the other follows about 2 seconds later. When starting music, there is a 3 second delay in sound coming out so you miss the start of the first track. I've not found this with other Bluetooth devices I have. The current behaviour of these leads me to believe that either I have a faulty pair, or, B&O have rushed these out without fully testing them, or, I have a problem with all of my sources (iPod, iPad Air2) My guess is one of the first two. I'm not a happy bunny this morning after having so much enthusiasm for these. They sound lovely when they work but seem to be a practical nightmare in use. I'll let you know how it goes with customer serice. Dave.
Millemissen: Dave Farr: They are not picked up by the Beomusic app which seems a bit stupid. Dave. Please don't expect that! The S3 is a bluetooth speaker, not a NL-enabled product. The BeoMusic is a control app for NL-enabled devices - and it has no playback of it's own, that could be streamed via bluetooth. MM
I don't think it's unreasonable to expect it. If, as it appears there is to be a wall or floor stand option for these and they are permanently sited, if I say use an A9 via Bluetooth in my dining room and have S3's in the kitchen, why not be able to transfer the output to them via the Beomusic app if that's how I was controlling the A9? surely it can't be that difficult?
OK, just got off the phone with Beoplay Customer Support (UK). Very helpful and were going through my e-mails to them regarding this.
They will report the autosense issues I've found to technical support for investigation. Yes, I had the line-in correctly fitted etc.
I asked about stand or wall mount options - these were originally thought of and incorporated in the product but there doesn't seem to be further development of them at present.
I explained why it made sense for them to be included on the Beomusic app and she is passing on to tech development.
Having both speakers just called 'S3' under Bluetooth devices on your iPad etc is an Apple issue that doesn't allow renaming of devices. However, the info is being passed on to tech support as they may be able to do something (e.g. include serial number) on a future software update.
Of course, as soon as I got onto the phone with them, the autosense worked! It hadn't most of the morning. Typical.
Seems that a trip to my B&O dealer is due 😻
Dave Farr:Absolutely! I hadn't realized they aren't available in the UK yet due to the way they are rolling them out. Your feedback on them once you visit your dealer will be most welcome. I'm measuring the threaded lugs tomorrow to see what size bolt will fit it as I may have a source for brackets. Watch this space! Dave.
Aussie Michael:Ooh Dave what about the stand that the playmaker has. That little table bracket?
No, that won't work. It needs to be bolted to the underside of the speaker in the threaded lugs I showed in the picture. Certainly for wall mounting or on a taller stand or table stand. Hopefully, watch this space.
I've had a reply from B&O Play about my points:
Oopps - the S3 seems to be a naughty little guy with his own ideas ;-)
At first I was happy to read, that it definitely would work (using the line-in connection) with an external source like the Essence. But after reading, that you have to put it to 'multiple speakers mode', I got puzzled again.
In my case I would only need one, since I would be happy with a 'mono-downmix' of the stereo input for that particular room.
So I'll be waiting patiently for further reports from you, Ina and the 'colleague, who knows all there is to know about the S3'.
I won't be able to drive to my dealer untill the end of the week - unfortunately.
A further update from Ina:
It seems that to play via the line in - even for only 1 speaker, you have to press the B&O logo for 8 seconds until it becomes Orange (puts it into 'Multiple Speaker Mode') for the line-in to be stable! I think new Beta Testers are needed as this is an awful solution. If I plug a line-in cable into something, I expect it to play - not to have to basically reprogram a device into something it isn't to work! It's a single speaker, how difficult can it be to play via line-in?
I'm amazed and shocked.
Millemissen: Oopps - the S3 seems to be a naughty little guy with his own ideas ;-) At first I was happy to read, that it definitely would work (using the line-in connection) with an external source like the Essence. But after reading, that you have to put it to 'multiple speakers mode', I got puzzled again. In my case I would only need one, since I would be happy with a 'mono-downmix' of the stereo input for that particular room. So I'll be waiting patiently for further reports from you, Ina and the 'colleague, who knows all there is to know about the S3'. I won't be able to drive to my dealer untill the end of the week - unfortunately. MM
One possible problem with this is that once a line-in cable is plugged in, the Bluetooth is disabled. So, if you have them wall mounted for example (assuming a bracket becomes available) you'd have to climb up and revert it back from multiple speaker mode or remove the line-in jack to play via Bluetooth. Completely impractical! I can't believe they haven't thought this through in a real World situation.
Dave Farr: One possible problem with this is that once a line-in cable is plugged in, the Bluetooth is disabled. So, if you have them wall mounted for example (assuming a bracket becomes available) you'd have to climb up and revert it back from multiple speaker mode or remove the line-in jack to play via Bluetooth. Completely impractical! I can't believe they haven't thought this through in a real World situation. Dave.
The (missing) bluetooth connection is not that important to me, since the line-in would be the main reason for me to buy/use the S3.
BUT, I am sure it is essential to others and it does need some kind of fix.
Luckily these things are software related - there is still a chance, that it can be fixed.
Their non-existent customer service that I received has truly destroyed them for me along with Dave's problems. I will not be wasting my hard earned money on the S3.
Raeuber:B&O seems not to be able to develop a properly working single speaker in the new digital world. They should go back to analogue world and use this connection:
They are using 'this connection' - it is just hidden inside the speaker 😸
Is there a simple way to connect these to my tv? I don't want them wireless by the way.
Opportunity!!!
If you are interested in 50% discount see here: https://www.dustinhome.se/product/5010880216/play-s3-white (black also listed)
At least for sweden, don't know about international shipping, but it is an opportunity I couldn't miss - ordered two immediately :)
NOTE!Offer is only valid this weekend as part of Dustin weekend-rush deals...
Apart from the fact, that the price, that they mention as the 'normal pris', is higher than the price on the BeoPlay-site and that it is listed as black even if the picture shows the white version, it seems eeeextremely cheap.
I am exited about, what my dealer says, when I show him that offer tomorrow 😏
https://www.dustinhome.dk/product/5010880213/play-s3-black
Same in Denmark, really good price.
Nah, too simple, they'd need special DIN speaker connectors that only accept tiny wires.
Jeff
Millemissen:Apart from the fact, that the price, that they mention as the 'normal pris', is higher than the price on the BeoPlay-site and that it is listed as black even if the picture shows the white version, it seems eeeextremely cheap. I am exited about, what my dealer says, when I show him that offer tomorrow 😏 MM There is a tv - and there is a BV.
Emil Jensen: https://www.dustinhome.dk/product/5010880213/play-s3-black Same in Denmark, really good price.
Thank you very much! I ordered a set of black ones at the blink of an eye
BeoVision Eclipse 55, BeoPlay S8 (sub+rears), BeoPlay A9 MKII (living room), BeoVision Avant 32 DVD (retro gaming, basement), BeoLab 4000 (entertainment room, basement), BeoSound 8 (workshop), 2x BeoPlay S3 (PC), BeoPlay A1, BeoPlay H2/H3 (on the go)
Beoberg:Thank you very much! I ordered a set of black ones at the blink of an eye BeoVision 11 - 40, BeoLab 9 (main), BeoSound 5/BeoMaster 5, ML/NL converter, BeoLab 4 (desktop), BeoLit 12 (kitchen), BeoPlay H3 (on the go)
Livingroom: BL3, BL11, BV11-46 Kitchen: Beosound 1 GVA, Beocom 2 Bathroom: M3 Homeoffice: M3, Beocom 2 Library: Beosound Emerge, Beocom 6000 Bedroom: M5, Essence remote Travel: Beoplay E8 2.0, Beoplay EQ, Beoplay Earset
Bought two White while crossing the Island of Fyn. Or rather, I instructed my girlfriend sitting in the passenger seat to buy, buy, buy....
epkgael:Interesting to hear what tour dealer says
My dealer just shook his head and said, that he couldn't even buy them (from B&OPlay) at that price.
He adviced me to buy one from DusinHome, if I need one - that is, what he would have done ;-))
It seems that a product like the S3 was not meant for the traditional Bang & Olufsen dealers, but for online resellers etc
The mobilephone provider Telia (in DK) sell them for 2000 DKK three shops down the road.
DustinHome must have gotten these really cheap - probably because they ordered a lot.
P.S. Nothing wrong with the sound and the build-quality (at that price level) - they sound/it sounds really good.
If anyone needs a stationary bluetooth speaker (for the kitchen, bath etc) - buy it!
Beosystem 4 , Beoremote One, Samsung LED 65 Zoll, ATV4 PUC, BL 8000 Frontspeaker, Center BL 7.1, BeoPlay S8 black Rear Wandhalterung, Beosound Essence MK2 mit IR an Beolink passiv an Bose 161 weiß, Beomaster 3000 mit Beocord 3000 an BeoVox CX50 weiß, BeoCom 1401 mit IR Control, BeoCom 2000 weiß, Beoplay M5, Ex-Beosound Ouverture RDS, Ex-BV 10-40 MK3 mit Beo4 DTV an Dreambox 500V2, Ex - Beoplay V1-40 weiß , Ex-BV 8-26 mit Beo4 DTV an Technisat Digit S2e PUC, ex BeoSound 3, Ex-Beolit 12 Darkgrey, ex B&O A8 Earphones
Hi Dave
So is the verdict that a pair of speakers can't be wireless linked in line in mode?
I see that you been in contact with the support but is this your final conclusion also?
This whole thing seams very strange and makes med sad as I just ordered a pair for this use!
I wanted to use it with my Iphone, thus howver the phone does not support APTx bluetooth and the sound with bluetooth would be shitxxty to say the least. My plan was to connect my Aiport express to the back as a backpack (the airport express have a very good analog dad built in) and use airplay to get loseless audio in stereo sound. I am confused why they actually show "iphones" in the manual as an iphone connected with normal ad2p bluetooth connection would sound as good as a homemade can speaker to be frank, why no airplay?!
With what you say now this is just to forget? If so I would need to return them. :-( I been reading the manual and it is not fully clear but i think the manual confirms your findings? What transmission technique do you think there is in-between the speakers? APTx or BnO own wireless protocol?
krstec:Hi Dave So is the verdict that a pair of speakers can't be wireless linked in line in mode? I see that you been in contact with the support but is this your final conclusion also? This whole thing seams very strange and makes med sad as I just ordered a pair for this use! I wanted to use it with my Iphone, thus howver the phone does not support APTx bluetooth and the sound with bluetooth would be shitxxty to say the least. My plan was to connect my Aiport express to the back as a backpack (the airport express have a very good analog dad built in) and use airplay to get loseless audio in stereo sound. I am confused why they actually show "iphones" in the manual as an iphone connected with normal ad2p bluetooth connection would sound as good as a homemade can speaker to be frank, why no airplay?! With what you say now this is just to forget? If so I would need to return them. :-( I been reading the manual and it is not fully clear but i think the manual confirms your findings? What transmission technique do you think there is in-between the speakers? APTx or BnO own wireless protocol?
maybe :-)
While i am against Apple in general a second hand iphone is one of the cheaper way to get a phone with a decent headphone jack audio quality. Now, these speakers are definitive marketed for the "general" iphone user i would claim freely, why this just does not make any sense. I am wondering if there maybe could be airplay built in the speaker but due to software delay is not enabled?! (why design a specific wireless only bluetooth chip in this speaker when it is cheaper to use same electronics as the other ones)
Or maybe i am just wishing here upon something that will never come true..
The S3' are tiny speaker made for convenient use with bluetooth.
They are what they are - and good (very good) so, nothing more!
Please don't 'overact' these small speakers.
They certainly aren't meant to replace other BeoLab speakers.
See them as a very good offer for those, who need a handy bluetooth driven stationary speaker.
Thanks for the tip on the S3's. You did however force me into buying four in white
I'm going to try them in my Sonos setup by buying two Sonos Connect. I'm a little anxious about the autosense as well as possible delays, which would disturb the synchronization.
I'll report back when it is up and running. If it does not work as expected I'll have to return them.
I'm excited to see if they are better than a pair of Play:1's.
Br
Anders
AndersKjergaard: Thanks for the tip on the S3's. You did however force me into buying four in white
The same did i, 3 for the kids and one for me
Can't wait to hear them
