BeoPlay A2 "Pairing Rejected" with iMac
trollerboy
Posts 4
trollerboy Posted: Fri, Sep 18 2015 8:27 PM
I have a BeoPlay A2 that is being rejected by my iMac - it sees the device, but rejects pairing and asks (under 'options') for a pairing code.  There is no pairing code, as far as I know.
Anyone have this problem?   I can pair the A2 with other devices.  iOS is fully updated.
L1NO
Posts 250
L1NO replied on Fri, Sep 18 2015 9:38 PM
Wat is the age of the mac ~ which model? And you've tried 1234 and 0000?
L1NO
Posts 250
trollerboy
Posts 4
trollerboy replied on Fri, Sep 18 2015 10:30 PM
Yes - tried 1234 and 0000 (and 9999)
iMac is running Yosemite and can Bluetooth with all my other devices.  unit is probably 6+ years old.
elephant
AU
Posts 8,219
elephant replied on Fri, Sep 18 2015 11:10 PM
trollerboy:
So probably a down level Bluetooth
There may be firmware flash that you could try
But I know in my case I am out of luck
BeoNut since '75
trollerboy
Posts 4
trollerboy replied on Fri, Sep 18 2015 11:16 PM
It would work if here were a pairing code.  Nobody knows that actual pairing code?
trollerboy
Posts 4
Also, software is updated to latest version and all other bluetooth items work fine, with no pairing issue.  There must be a pairing code for the A2 when pairing is rejected.
Nobody knows it?  Hello B&O some help here?
Radiomekaniker
Posts 49
Sound a issue when I tried to connect my h8 via Bluetooth too my PlayStation 3... I'm prompted for a pin code.
But there's no pin.
I know it's not the A2
/Kristian
Page 1 of 1 (8 items) | RSS
DigiCert Secured Site Seal
