beovision11 gapless playback
This post has 5 Replies | 3 Followers
musicman123
Posts 10
musicman123 Posted: Sat, Sep 19 2015 1:43 PM
I wonder if it's possible to get gapless audio playback on the bv11 by connecting an external USB harddrive Directly.
Regards,
Musicman
seethroughyou
UK
Posts 999
I'd be interested to know this and also:
Does cover art show?
Can it create playlists?
Can it be used as s basic music player?
Present: BL90, Core, BL6000, CD7000, Beogram 7000, Essence Remote.
Past: BL1, BL2, BL8000, BS9000, BL5, BC2, BS5, BV5, BV4-50, Beosystem 3, BL3, DVD1, Beoremote 4, Moment.
Millemissen
Flensborg, Denmark
Posts 14,680
seethroughyou:
1: yes, if your files are tagged properly.
2: no!
3: yes - very basic, if you are willing to do pretty much scrolling.
I would recomment, that you use a DLNA server, where you have your content (instead of a connected usb-drive) and a DLNA controller app (like PlugPlayer, 8Player, Bubble-UPnP etc to choose, what you want to play - and send it to the BV11.
musicman123
Posts 10
But using it with a DLNA server is not going to playback gaplessly is it? When I'm streaming music from my beosound5/beomaster5 it curtainly does not!
That is why I'm wondering if it would do that with a USB harddrive directly connected to the beovision11.
seethroughyou
UK
Posts 999
BS5/BM5 can play gapless files which have been ripped from CDs. I recall that clear from the time i owned it.
DLNA doesn't have gapless playing as far I know. You need a front end audio system or software that acts as a renderer to do this.
Millemissen
Flensborg, Denmark
Posts 14,680
musicman123:
I did not answer to that question, since I have no experience/knowledge of playing back from a connected USB-drive.
The BS5 plays gaplessly back from the BM5 without issues, because it basicly is a pc-based setup.
Using the DLNA server for playback on the BV11 does not provide gapless play.
Gapless playback is a 'problem child'' for any DLNA-based system, and requires some tweaking on the renderer site.
Page 1 of 1 (6 items) | RSS
