I wonder if it's possible to get gapless audio playback on the bv11 by connecting an external USB harddrive Directly.
Regards,
Musicman
Present: BL90, Core, BL6000, CD7000, Beogram 7000, Essence Remote.
Past: BL1, BL2, BL8000, BS9000, BL5, BC2, BS5, BV5, BV4-50, Beosystem 3, BL3, DVD1, Beoremote 4, Moment.
seethroughyou: Does cover art show? Can it create playlists? Can it be used as s basic music player?
1: yes, if your files are tagged properly.
2: no!
3: yes - very basic, if you are willing to do pretty much scrolling.
I would recomment, that you use a DLNA server, where you have your content (instead of a connected usb-drive) and a DLNA controller app (like PlugPlayer, 8Player, Bubble-UPnP etc to choose, what you want to play - and send it to the BV11.
But using it with a DLNA server is not going to playback gaplessly is it? When I'm streaming music from my beosound5/beomaster5 it curtainly does not!
That is why I'm wondering if it would do that with a USB harddrive directly connected to the beovision11.
musicman123: But using it with a DLNA server is not going to playback gaplessly is it? When I'm streaming music from my beosound5/beomaster5 it curtainly does not! That is why I'm wondering if it would do that with a USB harddrive directly connected to the beovision11.
I did not answer to that question, since I have no experience/knowledge of playing back from a connected USB-drive.
The BS5 plays gaplessly back from the BM5 without issues, because it basicly is a pc-based setup.
Using the DLNA server for playback on the BV11 does not provide gapless play.
Gapless playback is a 'problem child'' for any DLNA-based system, and requires some tweaking on the renderer site.
