Hello all,
I just wanted to get some advice about how I can integrate my Beosytem 7000 into my 'daily' entertainment setup. Currently all sources are routed through a non B&O av amp and all hidden in a sideboard with only the Beovox 3800 visible. My question pretty much centres around how I get the sound from various HDMI sources to the AUX IN of the Beomaster.
Current setup:
Bigger here
I've seen this HDMI switcer with audio out which seems like it would do the job but wanted to see if anyone had any other suggestions or maybe a better way of doing it?
This is what I'm currently aiming for:
MrRoast: My question pretty much centres around how I get the sound from various HDMI sources to the AUX IN of the Beomaster.
What you need is an HDMI Switch and Audio De-embedder.
That would give you the analog-out and a pass-through of the HDMI for your tv.
The one in your link should be fine.
Here is another one:
http://www.kanexpro.com/item/?id=SW-4KPROSLIM4X1
If your tv supports ARC (audio return channel) be sure to get one that supports ARC.
If you want to keep your current receiver, you could use a single HDMI De-embedder from the HDMI-out:
http://www.amazon.com/Kanex-Pro-De-Embedder-2-Channel-HAECOAX/dp/B009KAU0WO
Does your current receiver have audio pre-outputs?
Or maybe a digital audio output?
