System setup advice...
This post has 4 Replies | 0 Followers
MrRoast
Posts 340
MrRoast Posted: Tue, Sep 22 2015 8:08 PM
Hello all,
I just wanted to get some advice about how I can integrate my Beosytem 7000 into my 'daily' entertainment setup. Currently all sources are routed through a non B&O av amp and all hidden in a sideboard with only the Beovox 3800 visible. My question pretty much centres around how I get the sound from various HDMI sources to the AUX IN of the Beomaster.
Current setup:
Bigger here
I've seen this HDMI switcer with audio out which seems like it would do the job but wanted to see if anyone had any other suggestions or maybe a better way of doing it?
This is what I'm currently aiming for:
Bigger here
kallasr
Germany
Posts 2,562
kallasr replied on Tue, Sep 22 2015 8:35 PM
Does the AVR have Audio out (rca/cinch)?
Or does the TV have audio out?
Ralf
Millemissen
Flensborg, Denmark
Posts 14,680
MrRoast:
What you need is an HDMI Switch and Audio De-embedder.
That would give you the analog-out and a pass-through of the HDMI for your tv.
The one in your link should be fine.
Here is another one:
http://www.kanexpro.com/item/?id=SW-4KPROSLIM4X1
If your tv supports ARC (audio return channel) be sure to get one that supports ARC.
If you want to keep your current receiver, you could use a single HDMI De-embedder from the HDMI-out:
http://www.amazon.com/Kanex-Pro-De-Embedder-2-Channel-HAECOAX/dp/B009KAU0WO
Does your current receiver have audio pre-outputs?
Or maybe a digital audio output?
MrRoast
Posts 340
MrRoast replied on Tue, Sep 22 2015 10:10 PM
Thanks for the replies kallasr / MM Yes - thumbs up
As I don't have a surround setup I'm not bothered about keeping the AVR (it was purely a functional solution before I got the Beomaster).
It seems the best option is the HDMI switch with breakout audio - then I can keep all the wiring that is currently in place but have the Beosystem being used rather than just sitting looking pretty!
Cheers!
MrRoast
Posts 340
MrRoast replied on Sat, Sep 26 2015 7:55 PM
Well I bought an HDMI switch with audio output and everything working correctly sound wise! Unfortunately one of the HDMI inputs, the Sky+ HD, is purple tinged Sad
The Apple TV was the same until I switched the HDMI to RGB HI but I can't find any similar settings on the Sky box to change. Hmmm - always problems!
Page 1 of 1 (5 items) | RSS
