Beovision 12-65 NG, Beosystem 4, Beolab 7.2, Beolab 6000, Beolab 5, Beolab 4000, Playmaker, Beogram 5005, Beo4, Beo5, Beovision 7-32 MK3 (2x), Beovision 4.42, Beosystem 2 HD, Beolab 7.1, Beolab 7.4, Beovision 10-32, Beovision 6-26, Beosound Moment, Beosound 2300, Beosound Ouverture, Beogram TX2, Beogram 2404, Beomaster 3002, Beovox CX 75, Beovox CX 100, ibundo, Keyring.......
Beovision 7 40 mk 5 ,beovision 6x3, beosound 3000, beogram 3300 , 2 x lc2, 2 x beocom 1401, beocom 6000 x 2, 5 x beo4,
, 4 x beolab 4's, form 2, h2, a2,a1 and a beolab 2 😀😀
I think it would be easiest to strip out the panel and electronics of the BV5 and just use the case to house a new 42inch TV, with a cinema sound system in the base. Connect up with Lintronics to keep the Beo4.
Graham
Would ne great if I could use the original speakers :-)
Almost everything is possible. Just a matter of how much effort you want to put into it. :-)
You could even try to hook up a new panel on the existing BV5 chassis using VGA and UART commands.
Of course the easiest solution would be to rip everything out and just "hang" a new panel in there without any further integration...
