Change the panel on a BV5 or BV 4-42?
Newbie
Posts 248
Newbie Posted: Thu, Sep 24 2015 11:14 PM
Is it possibile to change the panel on both of this Beovisions?
As i know are these Panasonic Panels.
Would ist be possibile to put in newer ones with full HD?
Instead of the Beosystem2 a raspberry pi or an Apple Tv could do the work....
I have These two tvs as stand alone in my office and the kids room.
Maybe someone knows how to handle with this beautifull TVs.
Kind regards, Newbie
Beovision 12-65 NG, Beosystem 4, Beolab 7.2, Beolab 6000, Beolab 5, Beolab 4000, Playmaker, Beogram 5005, Beo4, Beo5, Beovision 7-32 MK3 (2x), Beovision 4.42, Beosystem 2 HD, Beolab 7.1, Beolab 7.4, Beovision 10-32, Beovision 6-26, Beosound Moment, Beosound 2300, Beosound Ouverture, Beogram TX2, Beogram 2404, Beomaster 3002, Beovox CX 75, Beovox CX 100, ibundo, Keyring.......
bramble
Posts 397
bramble replied on Fri, Sep 25 2015 7:44 AM
Think it would be a lot of work regarding the bv5 ie hdmi sockets would need to be in place etc
Would be great if it "could" be doneSmile
Beovision 7 40 mk 5 ,beovision 6x3,   beosound 3000, beogram 3300 , 2 x lc2, 2 x beocom 1401, beocom 6000 x 2,  5 x beo4,
, 4 x beolab 4's, form 2, h2, a2,a1 and a beolab 2 😀😀
vikinger
Vestri Kirkjubyr, UK
Posts 5,422
vikinger replied on Fri, Sep 25 2015 8:27 AM
I think it would be easiest to strip out the panel and electronics of the BV5 and just use the case to house a new 42inch TV, with a cinema sound system in the base. Connect up with Lintronics to keep the Beo4.
Graham
Newbie
Posts 248
Newbie replied on Fri, Sep 25 2015 8:42 AM
Would ne great if I could use the original speakers :-)
BeoMotion
Posts 384
BeoMotion replied on Fri, Sep 25 2015 8:50 AM
Almost everything is possible. Just a matter of how much effort you want to put into it. :-)
You could even try to hook up a new panel on the existing BV5 chassis using VGA and UART commands.
Of course the easiest solution would be to rip everything out and just "hang" a new panel in there without any further integration...
Page 1 of 1 (5 items) | RSS
