New member and question about Beocenter 4600
Steve
Norfolk, UK
Posts 6
Steve Posted: Fri, Sep 25 2015 8:19 PM
I had a fit of madness today and bought an untested Beocenter 4600 in a local auction as I had fancied one of these for quite a while. Upon getting it home everything appears to work apart from the turntable which in itself looks good, belt ok etc but it's obvious someone has been somewhat heavy handed with the speed / pause stop switch / control.
Checking the parts list in the manual and removing the bottom plate revealed several several components of the switch to be broken or possibly missing ...the potentiometer itself is merrily flapping in the breeze with nothing to fit into!
Am I on a hiding to nothing trying to find a replacement or components thereof?
Thanks in advance
Steve
Dave Farr
France
Posts 2,283
Dave Farr replied on Fri, Sep 25 2015 10:50 PM
Member 'Dillen' may have spares in his dungeon. It's based on the Beogram 1500 and beomaster 1500 so some parts are common if you can find a scrap donor. Lots usually on eBay etc.
Dave.
Steve
Norfolk, UK
Posts 6
Steve replied on Sat, Sep 26 2015 5:16 PM
Thanks Dave, I've had a look on the Bay of E without success. Looks like I need the whole shebang which looks like quite an involved affair - outlined in red in this diagram
I found the rod [10] floating about within the case and the potentiometer is there retained by it's wiring into the socket. [4] is damaged, [5] in bits, Super Angry damaged & the retainer [12] is awol too.
tournedos
Finland
Posts 7,357
tournedos replied on Sun, Sep 27 2015 2:13 PM
How often does one really need to adjust the pitch? I believe I got bored with that already when I was 10 or so Big Smile
The motor is servo controlled so it will hold the speed you've set. While looking for a donor unit, I would just set the correct speed once, secure the pot somewhere and rig the externally visible remains of the controls so that they look nice.
That's a very nice sounding system. The same turntable mechanism is shared by a number of music centres and Beograms, so the parts need not be from another 4600 (which may be harder to find).
--mika
Steve
Norfolk, UK
Posts 6
Steve replied on Sun, Sep 27 2015 7:58 PM
Thanks Mika. I grasp what you say about pitch but how do I get the turntable to actually run without the switch which I presumed was part of this assembly?
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Mon, Sep 28 2015 8:31 AM
Could some of this be what you are looking for:
http://beoparts.com//?s=beocenter+4600&search=Go
Steve
Norfolk, UK
Posts 6
Steve replied on Mon, Sep 28 2015 10:02 AM
Yes indeed Martin, some of those are the ones Yes - thumbs up
Page 1 of 1 (7 items) | RSS
