Hello,
can anybody send me the Service-Manual for the Beosound Moment?
Thank you for your help
Mirco
Dave Farr:Fifth time I've tried to reply! Bizarre app! Why would you need the service manual? If it's broken it will be under warranty as it's such a new product. If you mess with it, the warranty will be void. Take it to your dealer. Dave.
Dave.
Going from Mirco's other post, his BL18s are flashing orange after he did a reset to his moment. I suspect he is just trying to work out what's happening as his dealer may be closed for the weekend?
I think the service manuals Mirco show the technical connections and don't delve in to pairing issues.
Did you try turning off your speakers from the power waiting a little bit and turning back on?
Are your speakers connected to any other sources?
Kind regards,
thats why I am looking for the Manual.
Yes, I tried this but without any succes. I think I have to carry the Speaker to my dealer tomorrow.
Greetings
There's no service manual for the moment on this site, so I can't help you there.
I was thinking that if you had another source you could try and see if it is not the moment causing it
http://www.bang-olufsen.com/en/customer-service/product-support/loudspeakers/beolab-18
How about trying a reset on your Beolab 18? There is a reset button
