Service Manual Beosound Moment
Vintage_B&O
Germany
Posts 303
Vintage_B&O Posted: Fri, Sep 25 2015 10:14 PM
Hello,
can anybody send me the Service-Manual for the Beosound Moment?
Thank you for your help
Mirco
Dave Farr
France
Posts 2,283
Dave Farr replied on Fri, Sep 25 2015 10:41 PM
Fifth time I've tried to reply! Bizarre app!
Why would you need the service manual? If it's broken it will be under warranty as it's such a new product. If you mess with it, the warranty will be void. Take it to your dealer.
Dave.
Aussie Michael
Melbourne, AU
Posts 3,730
Dave Farr:
Dave.
Going from Mirco's other post, his BL18s are flashing orange after he did a reset to his moment.  I suspect he is just trying to work out what's happening as his dealer may be closed for the weekend?
I think the service manuals Mirco show the technical connections and don't delve in to pairing issues.
Did you try turning off your speakers from the power waiting a little bit and turning back on?
Are your speakers connected to any other sources?
Kind regards,
Vintage_B&O
Germany
Posts 303
thats why I am looking for the Manual.
Yes, I tried this but without any succes. I think I have to carry the Speaker to my dealer tomorrow.
Greetings
Mirco
Aussie Michael
Melbourne, AU
Posts 3,730
There's no service manual for the moment on this site, so I can't help you there.
I was thinking that if you had another source you could try and see if it is not the moment causing it
http://www.bang-olufsen.com/en/customer-service/product-support/loudspeakers/beolab-18
How about trying a reset on your Beolab 18?  There is a reset button
Page 1 of 1 (5 items) | RSS
