Hi
I have an apple tv1 connected to my avant as v.aux and controlled as apple remote through the stbc. It works fine but when i press menu i dont get a list of commands like you do with sky. So to switch it off means oing to settings and the. Selecting standby.
Does anyone know if there is a quicker wa and a list of the commands available. Tried holding down play/paise and stop but that didnt work. Does it automatically power off like the sky box or do i have to do it manuallyneverytime?
Unfortunately B&O did not implemented the Apple commands very well. It does not switch off. Just leave it, the power consumption on standby is quite the same as in operation.
Hi, i tried learning the commands, but there is no off. I will leave it on if i forget and switch it off if i remember!
