Beocenter 9300 aux
This post has 3 Replies | 0 Followers
Seanie_230
UK
Posts 2,278
Seanie_230 Posted: Thu, Jun 21 2012 8:15 PM
Hi all
So I have a beocenter 9300 connected to my system via a ml/mcl convertor.
Now with the beo4 I can select dtv or vmem etc and play it in the room when I do this AUX is shown.
Can I select these sources directly on the 9300 so I don't need the beo4
If this works what option do I use to disable the IR so it's completely touch only.
Cheers all
Eclipse 65
V1-32
Beosound M5
Essence MK2
BLI
Seanie_230
UK
Posts 2,278
Seanie_230 replied on Thu, Jun 21 2012 11:06 PM
Don't worry I found my old post I must have asked before
http://archivedarchivedforum2.beoworld.org/forums/p/33483/274394.aspx#274394
Seems I will have to use a beo4
Eclipse 65
V1-32
Beosound M5
Essence MK2
BLI
Yendys
Sydney
Posts 312
Yendys replied on Fri, Jun 22 2012 9:02 AM
Thats correct you need to keep the Beo4 to hand. It's the same for the 9000 range and even newer products extra sources/functions are added and then accessed through the list button.
Guy
Warwickshire
Posts 2,590
Guy replied on Fri, Jun 22 2012 12:11 PM
Why can't you put them both in Option 1 even though in different rooms - then use Aux 3 to select DTV etc.
Page 1 of 1 (4 items) | RSS
