Hi all
So I have a beocenter 9300 connected to my system via a ml/mcl convertor.
Now with the beo4 I can select dtv or vmem etc and play it in the room when I do this AUX is shown.
Can I select these sources directly on the 9300 so I don't need the beo4
If this works what option do I use to disable the IR so it's completely touch only.
Cheers all
Eclipse 65V1-32Beosound M5Essence MK2BLI
Don't worry I found my old post I must have asked before
http://archivedarchivedforum2.beoworld.org/forums/p/33483/274394.aspx#274394
Seems I will have to use a beo4
Why can't you put them both in Option 1 even though in different rooms - then use Aux 3 to select DTV etc.
