New software BV11
This post has 19 Replies | 4 Followers
mr_anders_son
sweden
Posts 1,710
mr_anders_son Posted: Wed, Oct 7 2015 6:57 PM
It says not what the change is...maybe Beolab 90 as option!?
BeoVision Haermony 65"...BeoLab 28 Anthracite....BeoLab 17 as REAR....BV10-32....BC6-26....Beosound 9000....Beosound 1 New York edt....Beogram 4002....Beoplay Emerge....Beoplay M5....Beoplay M3....Beoremote Halo....BeoRemote One BT....Beo6....Beo4....Beo4 Cinema....BeoLink 7000....Serene....H95 Black LTD....H9i Rimowa....6 x H6....Form 1....U70...
Michael
Sweden
Posts 2,578
Michael replied on Thu, Oct 8 2015 3:35 PM
That's probably the only difference. I've received the same update as well. I noticed in the technical sound guide that a beovision v1/11/avant and bsys4 can control beolab 90 over powerlink (and wisa probably). Quite interesting I think, since I thought B&O gave up on the data link features of powerlink.
Millemissen
Flensborg, Denmark
Posts 14,680
The BSys4/the Avant need to know, that the BL90'ies are used in the setup anyway.
Geoff Martin
Struer, Denmark
Posts 672
Michael:
I haven't written the update to the BeoVision Technical Sound Guide yet - it's coming, but not within the next couple of weeks I expect...
If you look in the Speaker Groups menu, you'll see a new item called "Speaker Preset" - this automates the preset control of the BeoLab 90.
When you make a preset on the BL90, you assign it a number in the BL90 App. To get a particular Speaker Group on the BeoVision to select that preset, you enter the number in the Speaker Preset menu on the TV.
Cheers
-geoff
Millemissen
Flensborg, Denmark
Posts 14,680
My V1-32 has gotten the update too.
I could have the BL90'ies in our guest-room.
No excuses anymore ;-)))
Except that there would not be much room for the guests, then ;(((
Would have to run them in 'single guy-one chair-very narrow beam-mode'.
riverstyx
SouthWest UK
Posts 938
riverstyx replied on Thu, Oct 8 2015 10:39 PM
Millemissen:
If you treat your guests with a pair of BL90s in their room and they then complain about lack of room, you are inviting the wrong guests! Big Smile
I'm sure you'd have an endless stream of volunteer guests from here who would not complain... In fact, can I be first to volunteer please Wink
Martin.
Millemissen
Flensborg, Denmark
Posts 14,680
I'll have to call 'Struer', then - to send me a pair for testing in a small room :-)
MARKFS
Posts 90
MARKFS replied on Thu, Oct 8 2015 11:14 PM
https://www.facebook.com/Bang.Olufsen.Ealing/photos/a.10151951856165972.1073741832.98711300971/10153721065670972/?type=3&theater
Philips Hue integration :)
Razlaw
Posts 4,345
Razlaw replied on Thu, Oct 8 2015 11:57 PM
MARKFS:
Very Nice! Is that part of the new software? Is the Gateway needed? How is it done?
vikinger
Vestri Kirkjubyr, UK
Posts 5,422
vikinger replied on Fri, Oct 9 2015 12:07 AM
Razlaw:
MARKFS:
Yes, just how is it done? Looks really interesting!
Graham
Razlaw
Posts 4,345
Razlaw replied on Fri, Oct 9 2015 12:51 AM
Answer of how to do was posted a little while ago the another thread,,,new idea catalogue.......through the Gateway
http://archivedforum2.beoworld.org/forums/t/16919.aspx
Razlaw
Posts 4,345
Razlaw replied on Fri, Oct 9 2015 12:53 AM
Sorry, I must not know how to post a link correctly as the link I posted does not work. Perhaps moderators can remove from post? Editing no longer works on Apple products, which I believe has been mentioned here before. As a result, I con not remove the defective link.
Michael
Sweden
Posts 2,578
Michael replied on Fri, Oct 9 2015 7:37 AM
Geoff Martin:
Michael:
Cheers
-geoff
Ah, I haven't had the chance to look yet but I will tonight. But I won't be able to try the presets so perhaps you could send me a pre-production pair of BeoLab 90 for me to test Wink.
Cheers //Michael
vikinger
Posts 5,422
vikinger replied on Fri, Oct 9 2015 11:06 AM
Razlaw:
Found the other thread. Thanks.
Graham
BeoGreg
South of France
Posts 1,417
BeoGreg replied on Wed, Dec 9 2015 10:24 PM
I have a new update tonight, waiting for you to install it first.
Doesn't say anything about the changes.
Razlaw
Posts 4,345
Razlaw replied on Thu, Dec 10 2015 2:59 AM
Also on V1. Installed but do not know what if anything it changed.
mjmedlo
Posts 922
mjmedlo replied on Thu, Dec 10 2015 3:20 AM
I updated it.
Nothing I noticed.
Michael
Sweden
Posts 2,578
Michael replied on Thu, Dec 10 2015 9:02 AM
It's probably new software for all bsys4 enabled units.
I wonder when the unused ports will gain functionality. Avant and Bv11 has a few ports "for future use".
Millemissen
Flensborg, Denmark
Posts 14,680
Even on a V1 there is an 'unused' control port.
I have often wondered, what that is for?
The control 1 and 2 are used for PUC.
Michael
Sweden
Posts 2,578
Michael replied on Mon, Dec 14 2015 10:52 PM
When muting the tv, with the new firmware installed, the sound fades out. Nice smoothness but too slow. Like ten seconds slow.
(Update: disregard, it was a bug. After rebooting it, mute was back to normal. It started to act weird when I adjusted the volume)
Page 1 of 1 (20 items) | RSS
