It says not what the change is...maybe Beolab 90 as option!?
BeoVision Haermony 65"...BeoLab 28 Anthracite....BeoLab 17 as REAR....BV10-32....BC6-26....Beosound 9000....Beosound 1 New York edt....Beogram 4002....Beoplay Emerge....Beoplay M5....Beoplay M3....Beoremote Halo....BeoRemote One BT....Beo6....Beo4....Beo4 Cinema....BeoLink 7000....Serene....H95 Black LTD....H9i Rimowa....6 x H6....Form 1....U70...
Beolab 50, Beolab 8000 x 2, Beolab 4000 x 2, BeoSound Core, BeoSound 9000, BeoSound Century, BeoLit 15, BeoPlay A1, BeoPlay P2, BeoPlay H9 3rd Gen, BeoPlay H6, EarSet 3i, BeoVision Eclipse Gen 2 55", BeoPlay V1-40, BeoCom 6000 and so much else :)
The BSys4/the Avant need to know, that the BL90'ies are used in the setup anyway.
Michael:I noticed in the technical sound guide that a beovision v1/11/avant and bsys4 can control beolab 90 over powerlink
I haven't written the update to the BeoVision Technical Sound Guide yet - it's coming, but not within the next couple of weeks I expect...
If you look in the Speaker Groups menu, you'll see a new item called "Speaker Preset" - this automates the preset control of the BeoLab 90.
When you make a preset on the BL90, you assign it a number in the BL90 App. To get a particular Speaker Group on the BeoVision to select that preset, you enter the number in the Speaker Preset menu on the TV.
Cheers
-geoff
My V1-32 has gotten the update too.
I could have the BL90'ies in our guest-room.
No excuses anymore ;-)))
Except that there would not be much room for the guests, then ;(((
Would have to run them in 'single guy-one chair-very narrow beam-mode'.
Millemissen: My V1-32 has gotten the update too. I could have the BL90'ies in our guest-room. No excuses anymore ;-))) Except that there would not be much room for the guests, then ;((( Would have to run them in 'single guy-one chair-very narrow beam-mode'. MM
If you treat your guests with a pair of BL90s in their room and they then complain about lack of room, you are inviting the wrong guests!
I'm sure you'd have an endless stream of volunteer guests from here who would not complain... In fact, can I be first to volunteer please
Martin.
I'll have to call 'Struer', then - to send me a pair for testing in a small room :-)
https://www.facebook.com/Bang.Olufsen.Ealing/photos/a.10151951856165972.1073741832.98711300971/10153721065670972/?type=3&theater
Philips Hue integration :)
MARKFS:https://www.facebook.com/Bang.Olufsen.Ealing/photos/a.10151951856165972.1073741832.98711300971/10153721065670972/?type=3&theater Philips Hue integration :)
Razlaw: MARKFS: https://www.facebook.com/Bang.Olufsen.Ealing/photos/a.10151951856165972.1073741832.98711300971/10153721065670972/?type=3&theater Philips Hue integration :) Very Nice! Is that part of the new software? Is the Gateway needed? How is it done?
Yes, just how is it done? Looks really interesting!
Graham
Answer of how to do was posted a little while ago the another thread,,,new idea catalogue.......through the Gateway
http://archivedforum2.beoworld.org/forums/t/16919.aspx
Sorry, I must not know how to post a link correctly as the link I posted does not work. Perhaps moderators can remove from post? Editing no longer works on Apple products, which I believe has been mentioned here before. As a result, I con not remove the defective link.
Geoff Martin: Michael:I noticed in the technical sound guide that a beovision v1/11/avant and bsys4 can control beolab 90 over powerlink I haven't written the update to the BeoVision Technical Sound Guide yet - it's coming, but not within the next couple of weeks I expect... If you look in the Speaker Groups menu, you'll see a new item called "Speaker Preset" - this automates the preset control of the BeoLab 90. When you make a preset on the BL90, you assign it a number in the BL90 App. To get a particular Speaker Group on the BeoVision to select that preset, you enter the number in the Speaker Preset menu on the TV. Cheers -geoff
Razlaw: Answer of how to do was posted a little while ago the another thread,,,new idea catalogue.......through the Gateway http://archivedforum2.beoworld.org/forums/t/16919.aspx
Found the other thread. Thanks.
Even on a V1 there is an 'unused' control port.
I have often wondered, what that is for?
The control 1 and 2 are used for PUC.
