Hi experts,
I have just finished re-foaming and it's the first time I've done this. The foams and glue came from Audiofriends, and fitting was all very straight-forward. I've tried them at low and medium volume and all sounds really good. Before cranking the volume up a bit, I was wondering how long I should leave the glue to set. This initial try-out was after 15 hours setting time.
How long should I leave the glue to set?
cheers
Nick
Depending on the glue, I leave mine (Arleene´s Tacky Glue) 24 hours, but 12 hours will probably do
I received this email from Audiofriends.
Many thanks. Actually, they are sounding very nice and solid now. But I'll bear in mind they may even improve with use.
