Beosound 5 Radio Favorites
This post has 16 Replies | 0 Followers
Razlaw
Posts 4,345
Razlaw Posted: Wed, Oct 14 2015 11:30 PM
How do I delete radio stations stored in the four color favorites on the Beosound 5?
And how do I add favorites to the numbered favorites in radio?
I select a station, go to favorites, press go, turn wheel to number I want to store in, and release go, but it does not store it.
Thanks.
Razlaw
Posts 4,345
Razlaw replied on Wed, Oct 14 2015 11:37 PM
I figured out how to delete the stations but now can not store new ones in colors or numbers. I select a station, while it is playing move the pointer to favorites, and then press and hold go. Nothing happens.
I am sure I am missing something simple. Have looked at user guide and have done in past, but now can not get to work. Thanks!
koning
holland
Posts 4,220
koning replied on Thu, Oct 15 2015 5:59 AM
Press and hold go and the color!
Then let go
Razlaw
Posts 4,345
Razlaw replied on Thu, Oct 15 2015 1:24 PM
I must be misunderstanding, or maybe my Beosound 5 is not working correctly.
I tried again and still no success.  Radio station is playing and displayed at far left of screen. I turn the pointer to favorites. The four colors and numbers appear. I turn the wheel to line up the desired color. Press and hold go. Nothing happens on the screen and nothing is saved to the selected color.
koning
holland
Posts 4,220
koning replied on Thu, Oct 15 2015 2:20 PM
That's strange.
Maybe you could do a reboot and then try it again.
Razlaw
Posts 4,345
Razlaw replied on Thu, Oct 15 2015 5:21 PM
That's a good idea. I will try it.
koert2
Posts 21
koert2 replied on Thu, Oct 15 2015 7:20 PM
Razlaw,
One thing I noticed on mine. When Radio was playing which was part of let's say green list and I tried to add it as NO 3 -> nothing happened, i.e. you case. However if I looked up the station again via Countries->Netherlands->"radio station" and I selected and held GO then I was able to add to number or color.
Koert
koert2
Posts 21
Razlaw,
Koert
Razlaw
Posts 4,345
Razlaw replied on Thu, Oct 15 2015 9:24 PM
Thanks for both suggestions. Unplugged the Bombaster and plugged back. Also tried going to Countries and selecting station in that manner first, neither worked.  My Beomaster 5 must be failing.
Razlaw
Posts 4,345
Razlaw
Posts 4,345
Razlaw
Posts 4,345
Razlaw
Posts 4,345
Razlaw
Posts 4,345
Razlaw replied on Thu, Oct 15 2015 9:26 PM
Sorry for the duplicate posts and spell check changing Beomaster to Bombaster. Was having difficulty getting post to go through. Perhaps moderators can remove all but one.  I would delete and put duplicate in the posts but editing no longer works with Apple products.
Razlaw
Posts 4,345
Razlaw replied on Thu, Oct 15 2015 9:32 PM
I think figured out what I was doing wrong.  I was pressing go while station was playing. What I should have been doing, it seems like, is when I press go to select station, immediately  move pointer to favorites while still holding go down.  Thanks for the suggestions.
Duels
England
Posts 2,553
Duels replied on Thu, Oct 15 2015 9:44 PM
Razlaw:
I like the name bombaster!
Razlaw
Posts 4,345
Razlaw replied on Fri, Oct 16 2015 12:55 AM
Smile
Page 1 of 1 (17 items) | RSS
