How do I delete radio stations stored in the four color favorites on the Beosound 5?
And how do I add favorites to the numbered favorites in radio?
I select a station, go to favorites, press go, turn wheel to number I want to store in, and release go, but it does not store it.
Thanks.
I figured out how to delete the stations but now can not store new ones in colors or numbers. I select a station, while it is playing move the pointer to favorites, and then press and hold go. Nothing happens.
I am sure I am missing something simple. Have looked at user guide and have done in past, but now can not get to work. Thanks!
Press and hold go and the color!
Then let go
I must be misunderstanding, or maybe my Beosound 5 is not working correctly.
I tried again and still no success. Radio station is playing and displayed at far left of screen. I turn the pointer to favorites. The four colors and numbers appear. I turn the wheel to line up the desired color. Press and hold go. Nothing happens on the screen and nothing is saved to the selected color.
That's strange.
Maybe you could do a reboot and then try it again.
Razlaw,
One thing I noticed on mine. When Radio was playing which was part of let's say green list and I tried to add it as NO 3 -> nothing happened, i.e. you case. However if I looked up the station again via Countries->Netherlands->"radio station" and I selected and held GO then I was able to add to number or color.
Koert
Thanks for both suggestions. Unplugged the Bombaster and plugged back. Also tried going to Countries and selecting station in that manner first, neither worked. My Beomaster 5 must be failing.
Sorry for the duplicate posts and spell check changing Beomaster to Bombaster. Was having difficulty getting post to go through. Perhaps moderators can remove all but one. I would delete and put duplicate in the posts but editing no longer works with Apple products.
I think figured out what I was doing wrong. I was pressing go while station was playing. What I should have been doing, it seems like, is when I press go to select station, immediately move pointer to favorites while still holding go down. Thanks for the suggestions.
Razlaw:Sorry for the duplicate posts and spell check changing Beomaster to Bombaster. Was having difficulty getting post to go through. Perhaps moderators can remove all but one. I would delete and put duplicate in the posts but editing no longer works with Apple products.
