BeoPlay A2 Software Update Failed
This post has 3 Replies | 0 Followers
Mark-N
Maryland, USA
Posts 320
Mark-N Posted: Sun, Oct 25 2015 10:56 PM
I just tried to update an A2 I got for a friend after successfully updating my 2 A2's.  It proceeded to go ok, it started updating, then I got a software update failed.  Unplug the usb cable and plug back in and try again.  I did so and the unit appears to be dead.  No power supply light when I plug in the power.  Nothing happens when I try to power it on.
Has anyone seen anything like this?  Is the unit completely dead?
Daniel
Svinarp, Sweden
Posts 1,632
Daniel replied on Mon, Oct 26 2015 5:57 AM
Hi, there is a thread about this here on BeoWorld. You can find by using the search function.
Cheers!
BeoGreg
South of France
Posts 1,417
BeoGreg replied on Mon, Oct 26 2015 6:46 AM
The result was a unit changed under warranty.
Dave Farr
France
Posts 2,283
Dave Farr replied on Mon, Oct 26 2015 11:46 AM
Yes, that was mine and apparently the only unit B&O had this happen to - until now by the look of it.
Contact Beoplay customer support and explain the failure. Return it to them - they sort out UPS to collect it from you at their expense. They will fix it or send you a new one. I had a new one within 7 days. Excellent service. All the better if you were sensible enough to keep the original box.
Dave.
Page 1 of 1 (4 items) | RSS
