I just tried to update an A2 I got for a friend after successfully updating my 2 A2's. It proceeded to go ok, it started updating, then I got a software update failed. Unplug the usb cable and plug back in and try again. I did so and the unit appears to be dead. No power supply light when I plug in the power. Nothing happens when I try to power it on.
Has anyone seen anything like this? Is the unit completely dead?
Hi, there is a thread about this here on BeoWorld. You can find by using the search function.
Cheers!
