Beotime - working with Lutron lights?
This post has 10 Replies | 2 Followers
Chris Harrison
Peak District
Posts 381
Chris Harrison Posted: Sun, Jun 24 2012 10:47 AM
I understand the main function of Beotime is a remote control and alarm clock. As it works with Lutron Rania (B&O Version) - when the alarm goes off will it turn the lights on for you?
Thanks.
Beosound 8, Beotime, Beocom 4, Beo 5, Lutron Rania, MacBook 15" (Mid 2015), iPad Pro, iPhone 6S, B&O Play H3, Beolit 12, Form 2, A8 Headphones, B&O Play A1, B&O Essence
Jasper050
Posts 12
Jasper050 replied on Mon, Jun 25 2012 3:20 PM
As far as I can see there is no possibility to turn on the lights when the alarm goes on.
You can however turn on the light with the Beotime even when it is connected to the Lutron Rania.
stefan
200 miles from Struer
Posts 2,920
stefan replied on Mon, Jun 25 2012 3:37 PM
If your Lutron lights respond to Beo IR commands in LIGHT mode, Beotime is able to control your Lutrons by the alarm function.
You just have to configure the Beotime to MLGW.
Stefan
Jasper050
Posts 12
Jasper050 replied on Mon, Jun 25 2012 4:04 PM
I don't have a clue what MLGW is?
Jasper050
Posts 12
stefan
Posts 2,920
stefan replied on Mon, Jun 25 2012 4:12 PM
Sorry - MasterLink GateWay. You don`t need one, you just set up your Beotime for use with the MLGW.
Stefan
BeoHut
Posts 482
BeoHut replied on Mon, Jun 25 2012 4:20 PM
Jasper050:
It is possible to turn the lights on (together with the alarm) with the BeoTime.
You just do not need a MLCW.
Handle like this:
- hold and press the menu-button for 10 seconds
- then, keep holding/pressing the menu button, and pull/push the sidewaybutton 4 times in and out.
Now you have an extra menu for the lights, including modes.
This works for me.
Succes!
Beofan53
Jasper050
Posts 12
Jasper050 replied on Mon, Jun 25 2012 6:34 PM
Thanks this works with and without the Lutron Rania.
Is there also a way to prefend the Beotime from beeping when the alarm goes off?
Music an light is more then enough to get me awake.
BeoHut
Posts 482
BeoHut replied on Mon, Jun 25 2012 7:47 PM
The alarmbel of the BeoTime cannot be switched off.
One reason is that is "always" awake you, even when the musicsystem does not swtch on or when you did not wake up, by just turning on the lights.
Thats how b&o developed this beautiful timepiece!
Chris Harrison
Peak District
Posts 381
I know from past that the remote area of lutron rania is fairly poor, I.e. you actually have to point the remote at the lights. Is this the case with the beotime? Thanks.
valve1
The south of France and occasionally Dublin Ireland
Posts 1,502
valve1 replied on Tue, Jul 10 2012 8:38 AM
Chris Harrison:
I have two ranias and never had to point the remote at the light switch.
Page 1 of 1 (11 items) | RSS
