I understand the main function of Beotime is a remote control and alarm clock. As it works with Lutron Rania (B&O Version) - when the alarm goes off will it turn the lights on for you?
Thanks.
Beosound 8, Beotime, Beocom 4, Beo 5, Lutron Rania, MacBook 15" (Mid 2015), iPad Pro, iPhone 6S, B&O Play H3, Beolit 12, Form 2, A8 Headphones, B&O Play A1, B&O Essence
As far as I can see there is no possibility to turn on the lights when the alarm goes on.
You can however turn on the light with the Beotime even when it is connected to the Lutron Rania.
If your Lutron lights respond to Beo IR commands in LIGHT mode, Beotime is able to control your Lutrons by the alarm function.
You just have to configure the Beotime to MLGW.
Stefan
I don't have a clue what MLGW is?
Sorry - MasterLink GateWay. You don`t need one, you just set up your Beotime for use with the MLGW.
Jasper050:As far as I can see there is no possibility to turn on the lights when the alarm goes on. You can however turn on the light with the Beotime even when it is connected to the Lutron Rania.
Thanks this works with and without the Lutron Rania.
Is there also a way to prefend the Beotime from beeping when the alarm goes off?
Music an light is more then enough to get me awake.
I know from past that the remote area of lutron rania is fairly poor, I.e. you actually have to point the remote at the lights. Is this the case with the beotime? Thanks.
Chris Harrison:I know from past that the remote area of lutron rania is fairly poor, I.e. you actually have to point the remote at the lights.
I have two ranias and never had to point the remote at the light switch.
