The lid on my beocenter is stuck in open position. Nothing happens when I press the cd button and no sound is heard. What do I do?
//riis
riis: The lid on my beocenter is stuck in open position. Nothing happens when I press the cd button and no sound is heard. What do I do? //riis
When you say 'nothing hapens' - does the CD spin? Do any of the indicator lights work? Is there any motor noise for the door mechanism?
You can gently close the door manually by gently holding the edge and pulling it across, then from the top, ease it closed. I have to do that on one of mine in that series as the door mechanism needs cleaning or the mechanism adjusting.
Dave.
I managed to close the lid the way you told me. When I press cd the lid opens about 2 cm and then stops.
Ok, I'll try to open it tomorrow. How do I open it in service position?
For another try you can use a flat screwdriver to turn the mechanism. Insert it through the hole left to the infrared window. It is in the area, where the gap pf the lid is. When you can turn and move the lid, the belt must be worn out.
when I turn I can open and close the lid. Does that mean that the belt is worn out???
Yes, it seems so. And if the belt is loose, you should also hear the motor working for a few seconds.
riis: Ok, I'll try to open it tomorrow. How do I open it in service position?
It can be opened like a chest, but the hinge is at the front. You find the instruction printed on the bottom plate
