beocenter 9300 lid problem
This post has 10 Replies | 2 Followers
riis
Denmark
Posts 270
riis Posted: Thu, Nov 5 2015 2:40 PM
The lid on my beocenter is stuck in open position. Nothing happens when I press the cd button and no sound is heard. What do I do?
//riis
Dave Farr
France
Posts 2,283
riis:
//riis
When you say 'nothing hapens' - does the CD spin?  Do any of the indicator lights work?  Is there any motor noise for the door mechanism?
You can gently close the door manually by gently holding the edge and pulling it across, then from the top, ease it closed.  I have to do that on one of mine in that series as the door mechanism needs cleaning or the mechanism adjusting.
Dave.
riis
Denmark
Posts 270
riis replied on Thu, Nov 5 2015 3:59 PM
I managed to close the lid the way you told me. When I press cd the lid opens about 2 cm and then stops.
riis
Denmark
Posts 270
Dave Farr
France
Posts 2,283
Yes, it's trying to go through the CD load cycle. Open, put CD in etc. Once it's tried to open, if you close it again manually, it should think the CD has loaded and try to play - if you press CD it will try to open again.
Any motor noise or indication the CD tries to spin?
It looks like the door wants to operate. I think it will need to be opened up, the runners cleaned as they are probably full of dust which is causing the problem.
Dave.
riis
Denmark
Posts 270
riis replied on Thu, Nov 5 2015 7:02 PM
Ok, I'll try to open it tomorrow. How do I open it in service position?
Dave Farr
France
Posts 2,283
I haven't looked so don't know but some BM's and BC's tell you underneath which screw to remove. Gold and Silver members here on Beoworld have access to the service manuals which is well worth the small outlay. Some service manuals can be found freely via a Google search.
Alternatively, do a forum search on the BC9000 series and the answer may be in there. Also, maybe a more accurate or succinct diagnosis and fix.
Dave.
ProGram
59269 Beckum, Germany
Posts 383
ProGram replied on Fri, Nov 6 2015 5:25 AM
For another try you can use a flat screwdriver to turn the mechanism. Insert it through the hole left to the infrared window. It is in the area, where the gap pf the lid is. When you can turn and move the lid, the belt must be worn out.
riis
Denmark
Posts 270
riis replied on Fri, Nov 6 2015 8:17 AM
when I turn I can open and close the lid. Does that mean that the belt is worn out???
ProGram
Posts 383
ProGram replied on Fri, Nov 6 2015 2:55 PM
Yes, it seems so. And if the belt is loose, you should also hear the motor working for a few seconds.
ProGram
Posts 383
ProGram replied on Fri, Nov 6 2015 3:00 PM
riis:
It can be opened like a chest, but the hinge is at the front. You find the instruction printed on the bottom plate
Page 1 of 1 (11 items) | RSS
