Hi Guys
Question, Is there a way to play Playstation while listening to the Spotify Feature on my Avant 55??
Many thanks in advance
Alex
- Flere
smile and enjoy the moment
With picture-and-picture this should be possible. Unfortunately you will always hear the sound of the bigger picture. So unless you would want to have only a very small picture area for your PS this probably won't be a solution.
With ML this was possible with the AV command. You could have the picture from a video source combined with the sound from an audio source.If my memories are right this isn't implemented in neither the current TV's nor NL itself.
BR,BeoMotion.
This should not really be a problem in a NL/multiroom setup, since most devices have several sources,
that can be shared/joined in to from all over the network.
However, if you have a specific source on your BV, that you want to use, it might be a problem.
Yes, you can play Spotify while playing Playstation on you r Beovision.
Start music from Spotify on your Playstation, and start playing.
https://www.vg247.com/2015/03/30/spotify-now-available-on-ps3-and-ps4-lets-you-play-music-in-the-background/
