Beosound moment issues
Richy437
Posts 4
Richy437 Posted: Fri, Nov 6 2015 9:51 PM
hi, i have a beosound moment but seem to get quite a few problems with it losing signal and the remote locking up and needing to be reset via the hidden switch near the charging connectors. I also notice that most of the album artwork does not show up. I have the system hardwired to a router running superfast broadband and use deezer for the music source. The other main issue i get is when you just tap it to play something supposedly to suit your mood and time if dat, it always plays from favourite tracks only. Is this correct? Any help would be greatly appreciated.
StUrrock
Posts 995
StUrrock replied on Fri, Nov 6 2015 10:16 PM
Richy437:
If you are unhappy sell it or get a refund.
In my home owning a BeoSound 5 nearly caused a divorce.
We kept the lovely BeoLabs, switched to another music system and are still happily married.
Millemissen
Flensborg, Denmark
Posts 14,680
I'd say hi Richy437 and welcome to Beoworld,
there are quite a few threads on the BS Moment on the forum.
I am sure you can find some help (and maybe solutions) to your 'problems', if you use the search function.
Brigantinus
Posts 140
Hi Richy,
how long do you have the Moment? It takes a little time, that the Moment can "learn" your habits, suddenly the mood wheel works with deezer, and the Pattern Play either.
BUT.... your habits guide the pattern play, so if you always listen to the same songs the same time, the Moment "learns".
Greetings
Richy437
Posts 4
Richy437 replied on Sat, Nov 7 2015 10:48 AM
Thank you for the advice, i will check what is being played. I have also found some other points on the forum as suggested by others which has also been of great use.
Thank you.
Page 1 of 1 (5 items) | RSS
