hi, i have a beosound moment but seem to get quite a few problems with it losing signal and the remote locking up and needing to be reset via the hidden switch near the charging connectors. I also notice that most of the album artwork does not show up. I have the system hardwired to a router running superfast broadband and use deezer for the music source. The other main issue i get is when you just tap it to play something supposedly to suit your mood and time if dat, it always plays from favourite tracks only. Is this correct? Any help would be greatly appreciated.
Richy437:hi, i have a beosound moment but seem to get quite a few problems with it losing signal and the remote locking up and needing to be reset via the hidden switch near the charging connectors. I also notice that most of the album artwork does not show up. I have the system hardwired to a router running superfast broadband and use deezer for the music source. The other main issue i get is when you just tap it to play something supposedly to suit your mood and time if dat, it always plays from favourite tracks only. Is this correct? Any help would be greatly appreciated.
I'd say hi Richy437 and welcome to Beoworld,
there are quite a few threads on the BS Moment on the forum.
I am sure you can find some help (and maybe solutions) to your 'problems', if you use the search function.
Hi Richy,
how long do you have the Moment? It takes a little time, that the Moment can "learn" your habits, suddenly the mood wheel works with deezer, and the Pattern Play either.
BUT.... your habits guide the pattern play, so if you always listen to the same songs the same time, the Moment "learns".
Greetings
Thank you for the advice, i will check what is being played. I have also found some other points on the forum as suggested by others which has also been of great use.
Thank you.
